Page 6 of 19 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 184
Like Tree2Likes
Thread: VOLVO S80 CarPC Work in progress
  1. #51
    Oct 2012
    Bulgaria
    In my case this will be done by the controller for the LCD up/down. I've seen ardiuno based StartUp/ShutDown controllers.
    It's not a good idea to use the signal from the door lock motor, because you could lock the car from inside. Many people when exiting my car pushes the lock button by accident. This would make the PC shut down, but you don't want that. There are other situations too when you lock/unlock the car but you don't mean StartUP/ShutDown the PC. So the most clever way is to use electronic device whether it will be arduino based or like mine - custom professionally made one. Mine is made especially for controlling these monitors + PC in a VOLVO P2 cars, and that was why I suggested you to give you the coordinates of the engineer who made it for me.
    To be clear: it's not a advertisement. This guy integrated a genuine GARMIN navi unit into the VOLVO Screen rti mechanics. Here is part of his worklog click (in Bulgarian, sorry). He is an engineer and his job is just right this - to design the electronics for automated devices - parking lots, auto car-wash lots and so on. A mouth latter he made for him self a controller for his needs - to lift the screen up and to power the Garmin unit (the one pictured in my previous post). I saw it and I asked him whether he would made some corrections to that controller, so that it would meet my needs. He said yes (he is almost done right now). I don't know the price, because he is my friend (member of Volvo Club Bulgaria) and he was so kind to tell me that and I'll pay only the electronic components and the PCB itself. His work will be free for me, but I'll have to wait for him to get some free time for this. I'm pretty sure he could make custom unit for most of hour CarPC needs. If anyone is interested in this, I'll give you his coordinates.
    Hope that in the next few weeks I'll be ready with my PCB's for the Flat Flexible Cable, and the controller will be here too. Then I'll make a video describing what it does, how and why.
    Meanwhile if you got any questions - just ask.
    My worklog: VOLVO S80 CarPC
  2. #52
    Jul 2010
    Barcelona Spain
    i want to know how you connect the vga in the lcd board to your pcb board (photos if it si possible) because now i have the connection with wires.
    and i agree with you is not great idea turn the pc when unlock the car........
  3. #53
    Jul 2010
    Barcelona Spain
    here my screen installed and working...
  4. #54
    Oct 2012
    Bulgaria
    Here is a trace of the path for VGA signal:
    And here are all the connections with their names:
    Hope you got the idea.
  5. #55
    Jul 2010
    Barcelona Spain
    ok.- i see. but you built this pcb???
    or a specialist built the pcbs?????
    is a great idea because i have all with wires and this is better than my screen.... i thik to make like you....
  6. #56
    Oct 2012
    Bulgaria
    The PCB's pictured in my previous post WILL be made by me.
    And because this is my first attempt in making a DIY PCB I decided to make a model of them first. That seems to be a good idea, because I found some errors in the easier way
    Hope that this weekend I'll be etching and soldering the real ones
    I'm using CorelDraw to draw it. I know there are special software for PCB's. Some of them are free. But, hey I'm good with Corel and definitely I'll make it faster compared to learning some other soft...
    However if you want the CorelDraw file, just ask. I'm pretty sure you'll need to make some corrections so that it would fit for you. Probably your elements would have different footprints, but if you wish I will give you the order numbers from farnell catalogue.
    To be clear: I build the PCB's for connecting the non-moving with moving part of the mechanics. Controller + StrartUp/ShutDown is made by a professional.
  7. #57
    Jul 2010
    Barcelona Spain
    but you need to change the connections in the lcd board controler or use the same conecctions???? this is my question...
  8. #58
    Jul 2010
    Barcelona Spain
    The place of you computer?? in the trunk? or where????
  9. #59
    Oct 2012
    Bulgaria
    Quote Originally Posted by xavipetit View Post
    but you need to change the connections in the lcd board controller or use the same connections???? this is my question...
    Ok this is the cable, right?
    All I need is to cut the VGA plug and place instead of it two 6 pin male connectors like these:
    Picture shows 5 pin connector, but i got some 6 pin, some 5 pin and some 4 pin MALE connectors.
    When I do that I'll got a ribbon cable with 12 pin male connector on one side and two 6 pin male connectors on the other side and I'll be able to connect it with the lcd controller using the original controller's connector and to this pcb:
    I guess you didn't read the thread from the beginning, but it's OK. We all don't
    The PC itself is a Intel mobo (motherboard) - BN2800MT, fitted in a box of stock Volvo 6 CD changer. The 6 cd changer in P2 old volvo's (1999-2002) is used for navi CD's and is useless for me, but is great for PC box, because it could be fitted in the trunk using the stock bracket for it. And what's more - it's close to the battery, has a stock view, there are cable canals going next to it. REM is near, too so that I could use some of the free fuse places and rewire them for my needs.
    Good night (err morning ...)
  10. #60
    Jul 2010
    Barcelona Spain
    sorry
    i see but i dont remember......
    i show you the location of my pc in progress....
Size:  135.6 KBName:  23.jpg
  1. 2002 Volvo S60 Work Log
    By PaulF in forum Worklogs
    Last Post: 07-30-2010, 03:58 PM
  2. My opel astra carpc (work in progress)
    By Harderstylez in forum Show off your project
    Last Post: 06-14-2010, 04:23 PM
  3. Replies: 26
    Last Post: 08-02-2008, 09:31 PM
  4. 1995 Volvo T-5R carpc install progress
    By z8man in forum Worklogs
    Last Post: 09-27-2006, 06:41 PM
  5. A work in Progress
    By xtraxmechx in forum Car Audio
    Last Post: 02-08-2006, 11:33 AM
