Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 86
Like Tree2Likes
Thread: A "Mac'd V"
  1. #11
    Nov 2012
    Here is a pic of some connector tie ins.
    30 gauge magnet wire.
  2. #12
    Nov 2012
    Here are pics of where I am at currently.
    Got the circuit boards and stuffed one and installed it.
    The switching works, but I have a horizontal sync problem I am working on.
    (multiple images)
  3. #13
    Nov 2012
    Here is my "dev lab" lol.
    Here is a pic of the problem.
    Too many sync pulses.
    I am gonna try a decade counter to try to get it down to every third sync pulse and maybe gate the RGB data.
    Failing that, I will replace the display with something more friendly.
  4. #14
    Nov 2012
    Cutting down the # of sync pulses may not be the viable option.
    Rather then "dumb down" the video from the computer to the OEM display I may see if the OEM video data is "smart" enough to sync up at the lower rate to a better display.
    It appears the OEM display is severely limited in capability.
    There is more then one way to skin a cat.
  5. #15
    Nov 2012
    Got another chip to add to the mix.
    This will give me a horz & vert sync pulse.
    Hope the data syncs up!
  6. #16
    Nov 2012
    Had to order parts (China) and taking some time to do some other projects.
    Will have progress report when I make some!
  7. #17
    Nov 2012
    Progress update.
    The OEM display just can't handle the bandwidth necessary for a minimum resolution computer display IMO.
    So........
    I am going to use a RGB to NTSC convertor to make the OEM info readable (hopefully) through the composite video input of the 800 x 600 TFT display I got from China.
    Just getting frustrated with trying to interface the OEM data to the new display via RGB because of timing issues.
  8. #18
    Feb 2013
    Did you ever get the converter to work for you? Working on my carputer in an 05 and would like to keep the stock info & warnings available.
  9. #19
    Nov 2012
    I had to take a break from this project and the delay in getting info from China suppliers (who feign ignorance when convenient) is pretty frustrating.
    However, I plan on working on it this month as the weather is better (I will not work well when cold) and I am over the flu.
  10. #20
    Nov 2012
    Some progress.
    I actually got a semblance of the OEM screen to display on my ext display!
    It is now a matter of determining the frequencies of the horz and vert sync frequencies after separating them from the composite sync.
    What a PITA.
  1. Replies: 0
    Last Post: 09-13-2007, 02:28 PM
  2. EVAL;RESULT;strcomp("$VAR1$";"$VAR2$")"
    By Chuck in forum Road Runner
    Last Post: 11-13-2006, 02:09 PM
  3. Replies: 2
    Last Post: 08-09-2004, 03:49 PM
