Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 85
Like Tree2Likes
Thread: A "Mac'd V"
  1. #51
    Nov 2012
    Here are pics of the modified radio front panel.
    The three position switch on the right selects: OEM data, ext VGA data, force rear camera.
    The push switch is for selecting VGA input, AV1, AV2.
    The rear view shows the mounting for the switch panel.
    I determined that you really only need to have the use of one, the input selector switch.
    The other switches set monitor modes so the remote takes care of that.
    The tiny hole in the front is an LED that shows power on for the display (red) and also valid input signal (green).
  2. #52
    Nov 2012
    Finished!
    Whoo Hoo!
    The modified OEM radio re-installed.
    The Mac Mini wired and installed (power supply is in center console)
    The 5 volt regulator and breath mint box I enclosed it in.
    The 5.1 decoder with the 5 volt regulator in circuit.
    Now all that is left are software applications.
  3. #53
    Nov 2012
    The newest part of this project is taking the OEM radio sound and running it through the system.
    I plan on converting the OEM to TOS then using an A/B TOS switch to toggle between OEM and the Mac Mini.
    I want to try to make it "seamless" so I may trigger the switch off the VGA select.
    I am also replacing the Mac Mini with a more powerful version (late 2009).
  4. #54
    Nov 2012
    Some parts came in so I finished this addition to the mix.
    The video A/B select has a X/Y output so I wired up the "Y".
    Makes for a nice (15") screen to watch a movie and listen to the 5.1.
    My version of the 21st century "drive-in".
  5. #55
    Nov 2012
    Here is a video showing the functions:
    http://www.youtube.com/watch?v=e_7SG...ature=youtu.be
  6. #56
    Nov 2012
    The IR remote control for the Mac Mini has a patch so the volume control will also work.
    Now I have all the functions I wanted.
    WHOO HOO!
    GizmoQ likes this.
  7. #57
    Nov 2012
    Update.
    Replaced the hard drive in the Mini Mac with an SSD and it boots a lot faster.
    Added more memory also.
    Wired up the reverse sense and now the rear camera comes on automatically.
  8. #58
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    Hey! I must admit this thread is pretty cool, man.
    I'm curious though: you said you upgraded the Mac mini with SSD and RAM...
    What were the specs before the upgrade? How much RAM is there after the upgrade?
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
  9. #59
    Nov 2012
    Thanks for the comps!
    The Mini had a 240 gig HD so the SSD swap was a wash.
    The Mini had 4 gig of memory and now it is 16, the max you can put in a 2009.
  10. #60
    Jan 2011
    Whew, quite an involved install here!
    Nice work, love the orientation of the Apple logo.
    Great find on the 5.1 decoder, I want to run optical to the trunk instead of RCA's. Been a couple years since I first started looking into this, but couldn't find anything other than decoders for gaming headsets and they didn't work for chit.
  1. Replies: 0
    Last Post: 09-13-2007, 02:28 PM
  2. EVAL;RESULT;strcomp("$VAR1$";"$VAR2$")"
    By Chuck in forum Road Runner
    Last Post: 11-13-2006, 02:09 PM
  3. Replies: 2
    Last Post: 08-09-2004, 03:49 PM
