Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 73
Like Tree2Likes
Thread: A "Mac'd V"
  1. #61
    Feb 2012
    Quote Originally Posted by heavymetals View Post
    Finished!
    Whoo Hoo!
    The modified OEM radio re-installed.
    The Mac Mini wired and installed (power supply is in center console)
    The 5 volt regulator and breath mint box I enclosed it in.
    The 5.1 decoder with the 5 volt regulator in circuit.
    Now all that is left are software applications.
    What chip did you use to power in that mintbox? Heat sync big enough?!
  2. #62
    Nov 2012
    Quote Originally Posted by psi3000 View Post
    Just a 5 volt regulator LM series.
    Mint box is the heat sink and mounted to the amplifier heat sink, no worries at all.
  3. #63
    Nov 2012
    UPDATE:
    Interfacing the OEM radio/nav to the 5.1 sound is the new project.
    Tried using LOC's and the distortion from the transformers is too much to bare.
    Going to use a differential to single end conversion chip (4, dual amps on one IC) to convert the differential signals (pre amplifier) from the OEM and mix them then feed to the 5.1 decoder.
    We shall see.
  4. #64
    Nov 2012
    UPDATE:
    Grabbed the audio feed from the radio and it is differential.
    Found a chip that will convert from differential to single ended and it works great.
    Now the problem is volume control as the OEM radio controlled volume via class II to the BOSE amplifier.
    What an engineering POS.
  5. #65
    Nov 2012
    UPDATE:
    I had to get two switching power supplies that put out 15 volts (adjustable) so I could supply the positive and negative rails for the chip to work.
    Then I found software that actually made it play through the Mac Mini.
    "Linein", "Soundflower", and "AU Lab".
    So now I have volume and tone control over the OEM audio feed.
    WHOO HOO!
  6. #66
    Nov 2012
    Here is the interface.
    2 ICs, 4 caps, 6 resistors.
  7. #67
    Nov 2012
    New update.
    Revisited the OEM display and tried some new modifications:
    Will either have good or bad news after testing.
  8. #68
    Nov 2012
    Got a picture on the OEM display, now just have to get it to sync.
    Goal is a NTSC back up camera input.
  9. #69
    Mar 2014
    hey you can help me with my project probably the only person I am trying to replace factory nav lcd with a Lilliput and factury nav is rb but it has horizontal sync, vertical sync and composite sync, can I just use the composite sync without v and h sync? is composite sync same as combined sync?
  10. #70
    Nov 2012
    Composite sync is the same as combined sync, but you will not be able to get the high resolution (600X800 and higher) using composite sync.
  1. Replies: 0
    Last Post: 09-13-2007, 02:28 PM
  2. EVAL;RESULT;strcomp("$VAR1$";"$VAR2$")"
    By Chuck in forum Road Runner
    Last Post: 11-13-2006, 02:09 PM
  3. Replies: 2
    Last Post: 08-09-2004, 03:49 PM
