Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 86
Like Tree2Likes
Thread: A "Mac'd V"
  1. #71
    Jul 2014
    First let me take a moment to kneel before you and convey my adoration for what you've accomplished. Now that thats out of the way...
    Whats the chances of someone with little circuitry knowledge and half-rate soldering skills copying what you've done? I have an identically equipped car and I'm trying to do nearly the exact same thing you've done. I won't be happy with the stock screen and its horrible resolution so I know I need to get video output to a more capable display as you have. I probably wont use the oem feed all that much, but it is needed for settings and whatnot.
    Since I probably know the answer to my question already, here comes the inevitable follow-up... Would you be willing to modify my radio as you have for compensation?
    I fear without some assistance/guidance my dreams of an in-dash carputer wont make it off the ground, and visor monitors aren't nearly as cool or functional.
  2. #72
    Nov 2012
    You can email me, PM sent.
    Thanks for the comps and interest.
  3. #73
    Nov 2012
    The new project is to decode the info (classII?) going to the BOSE amplifier, primarily the volume, so I can control the OEM radio/NAV volume to the 5.1 decoder.
    Another fun project.
  4. #74
    Feb 2015
    My god.
    This is the greatest thing I've ever seen!
  5. #75
    Feb 2012
    Just have to say amazing after reading through from the beginning.
  6. #76
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    This was a great read. Kudos for your work. I have recently picked up an 03 CTS and would like to do something like this. But seems to be too much challenge.
    What is/are the downside(s) to just removing the head unit altogether? I know I would lose out on some of the messages, but what else?
    Thanks.
    John
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  7. #77
    Nov 2012
    Quote Originally Posted by jmullan99 View Post
    Thanks.
    John
    It is easier to swap out the system on a CTS then a CTS-V.
    03's didn't have the "updated" radio/nav.
    Also, the CTS doesn't have the driver features, however, the V doesn't have the steering wheel controls.
    I want to thank all who read this and the compliments.
    If anyone needs any help or has ?'s, just ask.
  8. #78
    Feb 2009
    Thanks.
    What is the "updated" version?
    Mine looks like this
    03 Cadillac CTS
  9. #79
    Nov 2012
    That picture looks like the "current" model.
    I thought the CTS-V was the first to use a DVD map based nav where the earlier model CTS used a CD based nav (6 discs).
    You can "convert" your current unit, but I have also seen some "Parrot" installs that people seem to be happy with.
    http://ls1tech.com/forums/cadillac-c...-headunit.html
    I have hardware available if you want to "convert" your unit.
  10. #80
    Feb 2009
    The unit uses a single disc map which is kept in the top DVD slot. Bottom slot for single CDs.
    I will check out the Parrot unit.
    03 Cadillac CTS
  1. Replies: 0
    Last Post: 09-13-2007, 02:28 PM
  2. EVAL;RESULT;strcomp("$VAR1$";"$VAR2$")"
    By Chuck in forum Road Runner
    Last Post: 11-13-2006, 02:09 PM
  3. Replies: 2
    Last Post: 08-09-2004, 03:49 PM
