Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 105
Thread: 2004 Ford Ranger FX4 In Dash PC Project
  1. #21
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    The red is +12 switch to av1 for backup camera. That I can confirm working on mine.
    Black is auto display dimming but I did not hook up mine so cannot confirm it's +12v to activate, but supposed to connect to headlights... when on, screen dims.
    AV1 is the yellow RCA
  2. #22
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thx rray for the tips. Attached pic of bottom layout. Reading the manual to the p.s. and coming up with the wiring scheme.
  3. #23
    Jul 2005
    Motorcity
    Blog Entries
    1
    I need to do some research on the psu, as Greg send me an email about the output side being reversed, and it looks like the input side was also reversed, and perhaps fixed by the manufacturer? Is this something you did Greg? Definitely something funky going on here, as there is continuity between the ground lead and the fuse... and also continuity between IGN and VIN, and continuity between VIN and ground out. Glad I took a close look at this PSU before putting power to it, or connecting anything to it.
  4. #24
    Low Bitrate gla502's Avatar
    Jul 2007
    Hey Joe. No I didn't change any of the wiring but received that email from the PSU company so I sent it your way.
    That's all I have brother...
  5. #25
    Jul 2005
    Motorcity
    Blog Entries
    1
    I'm going to contact the manufacturer and figure it out as the manual is not much help.
  6. #26
    Jul 2005
    Motorcity
    Blog Entries
    1
    Not really surprised, but the manufacturer never responded to my inquiries. So I did more testing and traced leads and came to the conclusion that the inputs were reversed. This was correct, and the input wires were correct originally , somewhere along the line someone cut and solidered them backwards? Anyway, glad I got it figured out so I can progress on the remainder if the build.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  7. #27
    Feb 2012
    At least you can do your own troubleshooting
    Sent from my Galaxy Nexus using Tapatalk 2
  8. #28
    Jul 2007
    Joe glad you figured that one out...knew you would. Have you tried video on all inputs yet?
  9. #29
    Jul 2005
    Motorcity
    Blog Entries
    1
    So far in the previous pics I had it hooked up HDMI to a dvd player and finally got to do a burn in with all the hardware using VGA. Monitor is really good, the USB ribbon connector is slightly loose but I'll put a dab of silicone or expoxy on it to hold it closed. Manufacturer email back today and told me the out put was reversed, which is wrong because the input was the side actually reversed. I again requested a pin out but now I'll just make my own.
  10. #30
    Jul 2007
    Looking very good Joe! Keep the pics coming. Can't wait to see the final product! Looks like you removed that bulky right angle VGA connector. Did removing it allow for easier maneuvering?
  1. Replies: 166
    Last Post: 04-13-2007, 11:34 AM
  2. Ford Ranger/Ford Explorer Dash Kits?
    By DarkStar02 in forum Fabrication
    Last Post: 03-22-2007, 10:47 PM
  3. 2004 Ford Ranger
    By Rocky388 in forum Worklogs
    Last Post: 07-20-2006, 04:56 PM
  4. Replies: 3
    Last Post: 06-14-2006, 03:23 PM
  5. 2004 Ford Ranger Edge
    By Halo13 in forum Newbie
    Last Post: 03-18-2006, 04:11 PM
