Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 105
Thread: 2004 Ford Ranger FX4 In Dash PC Project
  1. #31
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Still using the 90, just removed it for the bench test so everything would lay flat.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  2. #32
    Jul 2005
    Motorcity
    Blog Entries
    1
    More assembley done, and some wiring. Customizing the power feed with solidered connections and marine grade shrink wrap. Ran into a slight problem. I don't think the power supply has a 5v+ rail, which means the 2.5 drive is not going to work, or a work around is done.
  3. #33
    Low Bitrate gla502's Avatar
    Jul 2007
    What sort of work around are you thinking of?
  4. #34
    Jul 2005
    Motorcity
    Blog Entries
    1
    Some sort of 12v to 5v voltage divider.
  5. #35
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    This might solve your 5v problem http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm SNO
  6. #36
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    That motherboard has an onboard SATA Power Connector, right next to the black SATA Port 0 connector, providing both the 12V and 5V needed for 2 hard drives. I don't know the current limits, but I would suspect at least enough for 2 notebook sized drives, as the included cable has 2 plugs on it.
  7. #37
    Jul 2007
    Awesome thanks rray
  8. #38
    Oct 2012
    Bulgaria
    Great job so far
    and according to the user manual of the mobo (I got the same too) you can use the 5V from SATA power connector fo feed devices up to 2.5A
    Quote Originally Posted by Intel DN2800MT TechProdCpec.pdf
    Board power supplied through the SATA power connector is rated at a maximum of:
    1.0 A from 12 V rail
    2.5 A from 5 V rail
    0.5 A from 3.3 V rail
    My worklog: VOLVO S80 CarPC
  9. #39
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thanks for the heads up guys. Now where to get the adaptor cable that plugs into the mobo? I've got a ton of random sata cables and none look the part.
  10. #40
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    ebay item # 290446162391 15 Pin SATA Male and Female Power Cable Right Angle
    The motherboard came with one like above, but has 2 hard drive connectors instead of 1.
  1. Replies: 166
    Last Post: 04-13-2007, 11:34 AM
  2. Ford Ranger/Ford Explorer Dash Kits?
    By DarkStar02 in forum Fabrication
    Last Post: 03-22-2007, 10:47 PM
  3. 2004 Ford Ranger
    By Rocky388 in forum Worklogs
    Last Post: 07-20-2006, 04:56 PM
  4. Replies: 3
    Last Post: 06-14-2006, 03:23 PM
  5. 2004 Ford Ranger Edge
    By Halo13 in forum Newbie
    Last Post: 03-18-2006, 04:11 PM
