Cool I will source that part. In the meantime more assembly! Shows how the LCD goes in.
Printable View
More pics! The bezel has two sides, one is Smooth and glossy, the other a "wrinkle" finish. Sometimes I'll paint the wrinkle flat black for an even cooler look, but I'll leave it up to Greg, as he will be the operator.
Was thinking something like this for the IR.
All green is good!
Joe it's looking amazing. I like the idea of the flat black bezel. How do you attach the bezel?
Thanks Greg! I was thinking Allen bolts or Velcro. The fit is snug, almost holds itself in place.
Back to the sata power problem, looks likes its a standard data power connector, but at the extreme end adjacent to the main power taps. Sure this isn't a power input?
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Are you asking if its a power input to the motherboard..if so, I'm sure that's not a power input. The only two inputs are the 2pin and the barrel connector.
Yes, it's a standard sata power connector and it's a OUTput power. It's there for you to be able to power a SATA HDD for example, because the mobo is supposed to be powered by just a 2 wire dc input. The mobo itself has an integrated voltage regulator, just like the one in M*'s PSU's. Some more info: This motherboard is rated to work with wide DC input range - 9-19v DC. This means you could plug it directly to the car battery and you'll be fine. The only problem could be when cranking - sometimes the voltage drops below 9v and this could cause the pc to restart. Forgetting the ability to "hit" the power button of the mobo (startUp/ShutDown controller) and preventing the input voltage drop below 9v, your PSU is useless in your setup. I use a Simple StepUp voltage regulator for ... 15 buks :)
So let's imagine this mobo is integrated in a device just like it's designed to be and it's powered by simple dc power adaptor (in the mall for example for playing some advertisements). How could you power a SATA HDD so that the videos could be stored there? There you should have regulated 12v, 5v, 3.3v to power the SATA device. And there you have it - this power OUTput from the mobo. You could use if without worry for power source as far as the devices you connect draws less than:
1.0 A from 12 V rail
2.5 A from 5 V rail
0.5 A from 3.3 V rail
The connector you got don't have the 3.3v cable (it's orange by default) but has only:
Black - GND
RED - 5V
Yellow - 12V.
These are the default colors, but be safe - check it with multimeter first!
And here you are the pdf with tech specs of your mobo:
Something more: I use a connector from old (burned) regular PC PSU. Just cuted the sata connector :) So I got 3.3v for powering some LED's :target:
where did you get the monitor from?
Ok I was thinking about making my own cable from an old power supply SATA lead. I assume the "L" SATA connector is standardized for red, yel, org & blk. Tanks for the link VolvoCarPC, I was going to look this up but you guys chimed in first. :)
I found a shorty SATA data cable to use aswell, its like 6".
