Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 105
Thread: 2004 Ford Ranger FX4 In Dash PC Project
  1. #51
    Low Bitrate gla502's Avatar
    Jul 2007
    @bmw_car_pc I got the monitor from ebay
    New SAMSUNG 7" LED LCD Touch Screen Monitor Kit Outdoor
    http://bit.ly/PYV7nR
  2. #52
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Sata power worked perfect. This is a really nice motherboard, in terms if quality and features. More work done, sata power harness done, more assembly , and first run closed up. Ended up drilling another while in the bottom to bring the monitor input board out front.
  3. #53
    Jan 2011
    I love the approach and planning you have towards this project. I like the fact that it is also clean, but here is a question. Even though the motherboard does not require a fan for the cpu and video chipset, do you have any plans for using fans?
    The reason I ask is that, after a year of using an in-dash computer in my Ridgeline, I had the the video chipset burn out due to head and lack of cooling even though I had a fan on the CPU cooler with its downdraft ample (or so I thought) on the video chip heat sink. The area behind the media console sits above the heat exchanger and gets pretty hot even with the lowest heat setting at static conditions. I have changed my setup completely and in the process of getting some parallel fan wirings ordered as I have the power supply (M4Atx), SSD, and MOBO along with the Video Chipset being cooled with 4 miniature fans.
    Good luck with your project and hope everything works in your favor
  4. #54
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I added a heatsink to the Graphics chip on mine because it was getting real hot. I used a substance called Heatsink Cement to attach a 20x20x15mm heatsink.
    The graphics chip is on the far left side in this picture:
    https://lh4.googleusercontent.com/-f...T%2520Card.jpg
    This is an upside down shot of the same space, but showing the graphics chip with a heatsink attached:
    https://lh3.googleusercontent.com/-W...2520Wiring.jpg
  5. #55
    Jul 2007
    Thanks for the info gentlemen but I've been fanless with my mustang CarPC for almost 6 years and its still running strong. Joe I'll take the chance, no need for fans.
  6. #56
    Oct 2012
    Bulgaria
    Mate, if you don't want fans - OK, but put a heatsink on video chip. Trust me.
    My worklog: VOLVO S80 CarPC
  7. #57
    Jul 2007
    Heat sink makes sense
  8. #58
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've had the system running for an hour and it really didn't make any heat. Granted it will be more enclosed once installed, but I also dont think this needs a fan.
    Working on the power supply config and timing, along with converting the touchscreen USB to an internal header to clean up and simplify the wiring. Getting very close to completion!
  9. #59
    Jul 2005
    Motorcity
    Blog Entries
    1
    More wiring done, leads shortened, extra USB ports added.
  10. #60
    Jul 2007
    Joe the build is looking great! Post more pics tonight if you can. Thanks
  1. Replies: 166
    Last Post: 04-13-2007, 11:34 AM
  2. Ford Ranger/Ford Explorer Dash Kits?
    By DarkStar02 in forum Fabrication
    Last Post: 03-22-2007, 10:47 PM
  3. 2004 Ford Ranger
    By Rocky388 in forum Worklogs
    Last Post: 07-20-2006, 04:56 PM
  4. Replies: 3
    Last Post: 06-14-2006, 03:23 PM
  5. 2004 Ford Ranger Edge
    By Halo13 in forum Newbie
    Last Post: 03-18-2006, 04:11 PM
