Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 105
Thread: 2004 Ford Ranger FX4 In Dash PC Project
  1. #81
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Looks like the items will be here tomorrow! Just wanted to give a Quick update.
  2. #82
    Low Bitrate gla502's Avatar
    Jul 2007
    Awesome! Thanks for keeping me posted
  3. #83
    Jul 2007
    Did it come in?
  4. #84
    Jul 2005
    Motorcity
    Blog Entries
    1
    Package arrived safe and sound. Have not opened it yet, helping out a friend with some electrical issues at his house. I'll open it up, inspect and install later this evening.
  5. #85
    Jul 2005
    Motorcity
    Blog Entries
    1
    Everything looks great, exact same LCD and controller. Going to enlarge the touchscreen channel a bit before installing. Should be able to wrap it up tomorrow and get it shipped out to you greg. I know your probably anxious to get it. I've gotta say that Derrick seems like a reliable source of fair priced, fast shipped (from overseas) touchscreens.
  6. #86
    Jul 2005
    Motorcity
    Blog Entries
    1
    This build would have also worked out well with derriks DD kit. It fits perfect into the Ford dash.
  7. #87
    Variable Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    I'm happy to hear Derrick's D-DIN fits the Ranger.
    I kind of want to build another car PC so I am thinking of putting my D-DIN unit in my 2007 Ranger, then learn some fabbing skills and try to fit an 8" to 10" screen in the Camaro.
    Sent from my SCH-I535 using Tapatalk 2
  8. #88
    Jul 2005
    Motorcity
    Blog Entries
    1
    New screen install went excellent. More dremel work to ensure a better fit of the ribbon cabling, and electrical tape to hold down the cables on the monitor during install, and some tape on the cable runners to smooth it out. I am finally 100% satisfied and the touchscreen is flawless. Looks like the controller board got a slight upgrade as well with the addition of a heat sink. Used even less Velcro this time on the screen, its seriously strong stuff, full bars were too much. Lastly I was at the cnc machine yesterday doing some work and decided to cut out another trim ring. I needed to make a small adjustment on the opening as the abs ring was shiwingva little bit of the brown outer ring of the touchscreen. 1mm did the trick. This time I used lexan, which the flat black paint is drying now.
  9. #89
    Jul 2005
    Motorcity
    Blog Entries
    1
    Paints dry!
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  10. #90
    Jul 2007
    Now that's a Ranger PC! Looks great! Can't wait to hear it in the truck. I'll be using this as my sub... Will fit under the seat with no problem and give me a just the right amount if base
  1. Replies: 166
    Last Post: 04-13-2007, 10:34 AM
  2. Ford Ranger/Ford Explorer Dash Kits?
    By DarkStar02 in forum Fabrication
    Last Post: 03-22-2007, 09:47 PM
  3. 2004 Ford Ranger
    By Rocky388 in forum Worklogs
    Last Post: 07-20-2006, 03:56 PM
  4. Replies: 3
    Last Post: 06-14-2006, 02:23 PM
  5. 2004 Ford Ranger Edge
    By Halo13 in forum Newbie
    Last Post: 03-18-2006, 03:11 PM
