Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 105
Thread: 2004 Ford Ranger FX4 In Dash PC Project
    Low Bitrate gla502's Avatar
    Jul 2007
    This Forum will show the progress of my 2004 Ford Ranger FX4 In Dash PC build.
    Member blk02si owner of ShockNET Computers www.shocknet.us has received all parts and is fabricating a chassis and laying out the design. He'll be posting pics of progress on his end and once it gets back I'll continue to post pics on the actual install.
    Look forward to communicating and sharing ideas.
    Parts list attached.
    V/r,
    GA
    Variable Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    I have a 2007 Ranger to do an in-dash mod to, after I finish the camaro mod in progress. I have similar hardware in the build I am working on now. The graphics chip gets warm on the DN2800MT board, so I put a heatsink on mine. Also, there are no 64 bit graphics drivers, so use a 32bit OS.
    Jul 2007
    Awesome rray! Thanks for the heads up on the OS. Did you use Tiny Windows 7 or 8?
    Apr 2012
    SF Bay Area
    I originally used Win7-64 but discovered I could not play spider solitaire because of there not being a 64bit graphics driver. Then I tried to install Win7-32 but my license would not work for 32bit.
    It was cheaper to buy the win8 pro 32bit upgrade so I downloaded and installed that, and used the win7 32bit drivers.
    Sent from my SCH-I535 using Tapatalk 2
    Apr 2012
    SF Bay Area
    By the way, what is Tiny Win7?
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Tiny Win7 (and TinyXP) are stripped down versions of the OS to install. They let you remove things that you may not need. The goal is a leaner OS that boots quicker and takes up less space.
    From my experience, it seems safer to just install the OS the way it was meant to be installed. That way, nothing is missing later on.
    Jul 2007
    ClockWork you make a very good point. I ran into issues installing the OS in my first build (2006 Mustang). I must say I love the boot speed of TinyXP.
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    As we all know a good chassis is the basis for any successful PC project, this ranger being no exception. This ranger presents a unique challenge as the dash is not din standard, and lacks the standard mounting provisions, but we are working around that. Today I fabricated the chassis parts necessary for mounting the PCB's, and picked up a sheet of abs for the LCD trim. More pics to follow as work progresses.
    -Joe
    Apr 2012
    SF Bay Area
    Cool, I have exactly the same dash in my 2007, but I used the Crutchfield free mounting kit when I installed a Pioneer single din radio. Watching with interest!
    Apr 2012
    SF Bay Area
    Just a quick question. I was looking over your hardware list and for the hard drive i noticed that you are using some kind of Flash based SATA device that connects to the SATA port. I was wondering what the advantage of using that type of drive connected to a SATA port as opposed to the mSATA devices that plug into the mini PCIe full size port?
    I have the same board and used a drive similar to this style, and found I need more than 64G so wonder if the one you selected is available in 128GB:
    Micron 64G mSATA SSD
    I figure I could plug that one (they type you have) into the other "gray" SATA port on the motherboard. Also, do you need to supply power or does it come from the SATA port itself?
  1. Replies: 166
    Last Post: 04-13-2007, 10:34 AM
  2. Ford Ranger/Ford Explorer Dash Kits?
    By DarkStar02 in forum Fabrication
    Last Post: 03-22-2007, 09:47 PM
  3. 2004 Ford Ranger
    By Rocky388 in forum Worklogs
    Last Post: 07-20-2006, 03:56 PM
  4. Replies: 3
    Last Post: 06-14-2006, 02:23 PM
  5. 2004 Ford Ranger Edge
    By Halo13 in forum Newbie
    Last Post: 03-18-2006, 03:11 PM
