Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
Like Tree1Likes
Thread: 69 Mustang project
  1. #31
    Aug 2005
    south GA
    so.. progress is slow, focus has been getting the 69 on the road and all the bugs worked out before Labor Day weekend for a event .. but, i did test the Sabre USB>Optical out connected to the MiniX and it works!!! to my amazement, with the Minix already powered on and hdmi connected to the monitor, i navigated to FLAC files i have been using for testing off of the NAS via ethernet and they streamed without any issue and the sound quality of the Sabre was still great... so, now i think i will shift focus on a front end layout for the MiniX and see how it goes. i will still try to work with the Nexus7, root it and install Timur's kernel, but im gonna run with the MiniX/Sabre combo for a bit. Should be interesting to do A/B testing with the opical out of the Minix and the optical out of the Sabre...
    also, back to the gauge cluster modifications, i finished extending the RGB LED wiring of my gauge cluster, adding the LED strand connectors at each end which will allow for daisy chaining more LED's for interior /under dash lighting, additional gauges in the console as well as door sill lighting..
    69 Mustang
    408 clevor AFD 2v heads - Viper T56
    Audio:RUX-C701, PXA-H701, MRV-F545, (2) MRD-M1005, SIR-SC-H1, DMHD1000, Dayton Audio: (2) RS180-4, (2) RS28F-4, (2) RSS265HO-44 DVC
  2. #32
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Fantastic !
  3. #33
    Aug 2005
    south GA
    this may be a hint as to why the Sabre USB DAC worked plug and play with the Neo MiniX5 ... either way... its time for me to learn android ... im just happy that it works!!
    69 Mustang
  4. #34
    Aug 2005
    south GA
    ok - progress getting the 69 on the road.... its driving under its own power... some alignment woes.. but we made it to its first event in Orlando, Mustangs at the Mickyard and earned a bronze trophy in its class... which was way more than what was expected..
    video of it running -
    http://youtu.be/c0R4tNd1m3c
    and
    http://youtu.be/ML9z9f6NZsc
    also with a squeaky belt ...
    http://youtu.be/1HSENAjXNaM
    as for the audio and interior portion, now i can focus on a few other items -
    currently researching/building a raspberry Pi (Fi) setup to determine if the DAC's i have purchased will work with the build... may be an interesting test.. we shall see.
    also installing various LED lighting throughout the car with LED sequential tail lights, backup lights as well as getting back on the gauge cluster arduino programming and interior LED lighting.
    more fun to come as the digital world hits an old school mustang..
    69 Mustang
  5. #35
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    came into this a bit late. :\ great looking build. Seeing how you seem to be comfortable with arduino i was going to suggest hacking a 2013 mustang gauge cluster (via can-bus protocol) and using those gauges for your build.
    im interested in your tube preamp. why did you choose to go with it , it looks to be two channel, how is it hooked up and how do you like it?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  6. #36
    Aug 2005
    south GA
    Quote Originally Posted by scott_fx View Post
    scott_fx -- thanks for the kind words.. i do plan on getting into Can-bus, the mustang gauge cluster sounds like an interesting idea ..
    as for the tube preamp .. i am into tube guitar amps, building, repairing etc, so i wanted the tube warmth in the audio of the 69, but with my current setup (ebay 12v based design) >> audio out of the H701 into the tube pre and then to the alpine amp ... its very easy to overload the the current tube setup... when i have the time to sit down and figure out a way to make it work with the correct tube circuit ... ill post it up...
    69 Mustang
  7. #37
    Dec 2004
    Los Angeles Ca
    awesome. im very interested in your results concerning the tube pre amp. I'll be following your updates. In my Corvette I had two phaze audio tube amps and they were by far the best amps i've ever had. I'm about to bite the bullet on a '66 Chevelle (hopefully this weekend) and was considering getting some butler audio tubes amps (he build the phaze amps) But if you get good results i may just pick up a another zapco (cheaper and i already have a 500x1 zapco) and do a pre amp like you.
    also, love the fact you're going dayton. very cool build
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #38
    Aug 2005
    south GA
    yeah i wanted to try the Dayton Audio setup .... i have read some good things about them and the price is definitely good along with the build quality of the components... nice choice on the 66 chevelle ... love that squared look.. im a Mustang guy but, lots of very nice muscle cars by all MFG's came out in the 60's and early 70's .... butler audio WOW i bet they sounded amazing ... i have never seen anything negative posted about them... on any forum..
    69 Mustang
  9. #39
    Aug 2005
    south GA
    raspyfi
    ok -- so i have been living with and loving the last week with raspyfi .. currently have it connected to my home audio setup via ethernet and usb ... into a soundvalves tube preamp, panasound solid state amp, Audio Research solid state amp, 60's dynaco speakers, Magnepan MG III's... switching between the two different speakers, testing out the Audio Research amp that a buddy loaned me... he wants to sell it to me... (crack dealer method)
    you can connect to the raspyfi via ethernet (wifi if setup) with a android device MPDroid (tablet, phone), ios device itunes (iphone,ipad), web browser etc .. so the possibilities are all around... i have it connected to a usb doc with a WD hard drive with flac, alac and some free DSD 96k 24bit files... so far so good.. sounds very very good... now with that said, i have not connected my Alpine gear to test the optical out of the DIYme .... if that didnt work.. now that would suck...
    so far so good!
    69 Mustang
  10. #40
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    That is one pretty car. Damn, I love hood scoops.
  1. '68 Mustang Project
    By skusa93 in forum Worklogs
    Last Post: 08-11-2009, 08:22 PM
  2. Mustang project
    By aztekbludd in forum Fabrication
    Last Post: 12-15-2005, 01:11 PM
  3. project media mustang is finished
    By kram in forum Show off your project
    Last Post: 02-10-2004, 11:47 PM
  4. 2000 Mustang GT Convertible Mp3 project
    By mp3stang02 in forum Show off your project
    Last Post: 05-24-2003, 04:45 AM
Tags for this Thread
