ok -- so the goal is to use multiple arduino micro-controllers(prototype) with RGB addressable LED pixel strings to control the gauge cluster lighting, interior lighting, turn signals, tail lights etc.. moving to atmega 328P circuit build once design is completed..
first tests are looking good, since the YearOne bezel did not come with turn signal or bright light indicators, i will program the far right and left to blink green when the appropriate turn signal is enabled, and also have the speedo gauge light blue when the bright lights are on.. the Shelby sequential tail lights should be fun with the arduino.. its all in testing at the moment, obviously the brightness will be the biggest challenge, adding enough RGB LED's to arrive at the brightness needed.. fun stuff..
initial testing of arduino and RGB pixel string--
http://youtu.be/nvF44YWayNQ
gauge cluster testing
http://youtu.be/WYsMujisIgs
night test
http://youtu.be/hfMQySYXTB8
LinkBack URL
About LinkBacks
