Page 7 of 13 FirstFirst 12345678910111213 LastLast
Results 61 to 70 of 130
Like Tree2Likes
Thread: Motorola XOOM - 2003 Jeep Grand Cherokee 4x4
  1. #61
    Feb 2008
    Hi,
    I was able to follow your setup with a WJ/WG CRD and a BT adapter.
    yet i suspect the BT OBD is draining the car's battery...
    On the CRD, unlike the V8, a week battery is catastrophic - the gear would always turn the MIL on while crancking due to the power drop :-(
    Any suggeustion?
    Rabin
  2. #62
    Sep 2009
    the OBDII port has a single +12v wire that is constantly powered, you can change that wire to pull from an ignition switched source instead to prevent battery drain. most people put in a switch so they can temporarily put it back to constant power when taking the vehicle to any sort of required inspections.
    alternatively there's this one with a sleep feature that says it's battery safe, but it's $100: http://www.scantool.net/obdlink-mx.html
    did you modify my steering wheel app to work with bluetooth?
  3. #63
    Sep 2009
    just this weekend i actually added a bluetooth OBD adapter to my setup for Torque/TouchScan/etc. i'm still using the USB adapter for the main steering wheel button interface.
    the problem with using 2 USB ones was that Android has no-way to identify which is which when they are the same type of device, and most apps don't check if one is in use - they just grab the first one. i made my steering wheel button app able to skip the first one it found if there were 2, but i still had problems sometimes after connecting/disconnecting and reconnecting with torque. it was just simpler to use a bluetooth one for the real OBD II apps.
  4. #64
    Sep 2009
    rear screen projector is nearly complete (for movies at camp!) - more details to come...
  5. #65
    Feb 2008
    Quote Originally Posted by theksmith View Post
    10x for the advice of disconnecting the power - I think i would eventually go to usb because the car radio BT is somehow very limited, it is a cheap device which lock the BT for phone voice usage only.
    but it works fine with my xoom.
    Regarding the BT and SteeringWheelInterface - I did it in opposite way, i just moved the ButtonActions.java file to the bluetooth android application sample: BluetoothChat .
    Also, i prefered using
    Context.sendOrderedBroadcast(...)
    over
    Runtime.getRuntime().exec("su -c input...")
  6. #66
    Jul 2009
    that is awesome
  7. #67
    Maximum Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    +1 Coolest thing I have seen in a long time!
    Sent from my SCH-I535 using Tapatalk
  8. #68
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Very nice! Cant wait till your writeup
  9. #69
    Constant Bitrate Lankin's Avatar
    Jun 2009
    Quote Originally Posted by camo.b View Post
    +1 Give us the deets! Very cool!
  10. #70
    Oct 2010
    Greece
    o think you ve just redefined the word camping ...!
    awesome !
  1. 2003 Jeep Grand Cherokee + PC
    By Bivio in forum Worklogs
    Last Post: 04-17-2008, 05:08 AM
  2. 97 Jeep Grand Cherokee
    By jfedel in forum LCD/Display
    Last Post: 04-11-2008, 02:31 PM
  3. Jeep Grand Cherokee
    By HUMAYUN in forum Show off your project
    Last Post: 12-15-2005, 12:49 PM
  4. VIA m10000/Travla c158/Xenarc 700 in 2003 Jeep Grand Cherokee
    By J.P. in forum Show off your project
    Last Post: 12-02-2004, 12:57 PM
  5. LCD for Jeep Grand Cherokee
    By darklord in forum LCD/Display
    Last Post: 07-30-2003, 12:07 AM
