Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Like Tree1Likes
Thread: The NEW Frontier A motorhome restoration.
  1. #11
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Small update: made bunch of purchases today. hedman headers, polished stainless steel hub caps, complete set of electronic gauges speedo/tach/fuel level/oil pressure/oil temp/water temp/trans oil temp/egt/vacuum/volts and a clock. I will need to do some major mods to the dash to accomodate. here's a couple of pics SNO
  2. #12
    Sep 2009
    looking forward to seeing your project progress! i can envision a main PC or Mac server connected to 1 or more displays, with it also serving content to and sharing an internet connection with multiple tablets for the passengers to be entertained on...
  3. #13
    Nov 2009
    Keswick,On Canada
    Dash gauges installed now to find a spot for the other 7
    and powered up
    since removing the factory insturments I need to add signals/high beam/parking brake lights x marks the spots
  4. #14
    Nov 2009
    Keswick,On Canada
    Motor going back together after a freshen up with a coat of paint and new cam 270dur 470lift/lifters/double roller chain and gears/headers/seals/water pump/fuel pump. Waiting for carb kit to arrive then I can fire it up.
    Name:  2013-06-02 19.09.05.jpg
    Name:  2013-06-02 19.07.26.jpg
  5. #15
    Constant Bitrate BADMOPAR's Avatar
    Mar 2007
    Sokolov, Czech Republic
    Nice, very nice SNO
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
  6. #16
    Nov 2009
    Keswick,On Canada
    Dash is just about done, alot of work with it not being obd2. I should be covered oil pressure and temp/water temp/exhaust temp/trans temp/fuel pressure/vacuum/volts for engine bat and volts for house bat/fuel level/tach and speedo.
  7. #17
    Dec 2010
    You need to add a turbo or centrifugal blower so you can also add a boost gauge
  8. #18
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Awesome progress. Definitely work to be proud of, I can't wait to see what comes next.
    Sent from my SCH-I535 using Tapatalk 2
  9. #19
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    a dash like that just screams 12 inch display .....
    View my worklog here
  10. #20
    Nov 2009
    Keswick,On Canada
    Roof joist's in, wiring reconnected and now insulation. Things are starting to move along now. SNO
    Before
    After
  1. Automatically bypassing 'Delete restoration data...'
    By WuNgUn in forum General Hardware Discussion
    Last Post: 10-11-2011, 03:55 PM
  2. my sunburnt dash restoration
    By jtc26 in forum Fabrication
    Last Post: 08-01-2010, 10:16 PM
  3. Suggestions for PC in motorhome
    By eksatx in forum Newbie
    Last Post: 02-13-2008, 02:41 PM
  4. Tag restoration
    By QnoisX in forum Fabrication
    Last Post: 07-02-2005, 04:53 AM
  5. Inverter options in a motorhome
    By greddy0 in forum Power Supplies
    Last Post: 10-06-2004, 12:13 AM
