Page 10 of 10 FirstFirst 12345678910
Results 91 to 100 of 100
Like Tree3Likes
Thread: Nexus 7 Sony App radio Install Tacoma
  1. #91
    Jul 2014
    Thanks for the prompt reply. In your setup are you streaming the audio/music from Nexus 7 over bluetooth to the HU? Or are you using a USB DAC? How is the sound quality in both cases?
    Could you please let me know?
  2. #92
    Sep 2014
    Quote Originally Posted by rups View Post
    I am very interested in this to. Are there newer models that don't need to hit this button to start the app? Has anyone looked at interfacing the arduino with a joycon or axxess steering controller? I have axxess now, and my buttons have a source button so I wonder if that would control the app starting. Truck is a 08 Silverado. I'm thinking about getting the deck just to see, because if the steering controls work to start the app this would be perfect.
  3. #93
    Constant Bitrate Lankin's Avatar
    Jun 2009
    Quote Originally Posted by Gduck24 View Post
    I cannot really account for newer units, as I have only had the model listed in the first post. As far as controlling with an arduino, this was discussed previously in this thread, although not pertaining to steering wheel controls. What has been confrimed is the ability to send ir commands that will allow the head unit to go into app mode and more, which is really the basis for control.
    In my setup I use bluetooth audio and it works fine. I imagine there would be a little more clarity if using a dac, but you have to remember that most of the control going on (Tablet, to head unit) is only possibly by connecting the tablet to the head unit over bluetooth. therefore using a dac to input the aux on the head unit is going to render the appremote aspect useless.
  4. #94
    Sep 2014
    Does Bluetooth audio work on everything soundwise? Meaning can I be listening to radio, and Google maps cuts in for directions?
    My thoughts on the setup is to use the aux 90% of the time and not to use the remote app interface. I would be able to swap to radio when I want, but I could use Google music and android apps in full function. If you were plugged in aux and turned off the vehicle does the radio come back on to the aux source?
  5. #95
    Jul 2006
    Quote Originally Posted by LastMile View Post
    I think which MENU option appears on the HU is based on what SOURCE you have selected. For example, if you have the SOURCE on TUNER and press MENU, you get the "SET APP REMOTE" option. If you have the source on BT AUDIO or BT PHONE, I think you get a different option (which means AppRemote won't activate). This is the biggest drawback of the Arduino solution: there's no real way to get output from the HU into the N7 as to which SOURCE the HU is currently on. The workaround to this is to set Tasker to cycle through the sources until you land on one that will go straight to the "SET APP REMOTE" option. So when the car is started, Tasker will open the UsbTerminal app and issue something like seven SOURCE commands. This is the equivalent to pressing the SOURCE button on the physical remote seven times. No matter what the SOURCE the HU is currently on, by "pressing" the SOURCE button seven times you will always land on a SOURCE that will take you directly to the "SET APP REMOTE" option. This allows us to keep the whole solution hands-free and automatic.
    Any updates on this? I'm in the process of putting my install together, and I was thinking there must be a more elegant way to get the arduino to invoke app mode. Does anyone know if there is a discrete code to go straight to app mode? Also, being an arduino newb, is there a way to have the arduino send the ir commands directly without having usbterminal open?
    Sent from my HTC One_M8 using Tapatalk
  6. #96
    Jul 2006
    Quote Originally Posted by barnyard View Post
    Ok, I really suck at coding, I just don't understand the language! With that said, I've had limited success with my second question above. I can get the arduino to send a couple IR codes to the radio completely independent of the tablet, but it's obviously missing something. I Basically set a variable "runitonce" to "1", then I copied the sound/menu codes, and the enter code, and then have it set the variable back to "0" so it won't just run forever. I've attempted to leave the other key assignments intact so I can still send commands to the radio if I need to. Is anyone fluent enough in arduionese to see what I'm doing wrong? I've probably got a bracket or something out of place, but like I said, I just don't get it!
    Code:
    #include <IRremote.h>
     * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
     * An IR LED must be connected to Arduino PWM pin 3.
     * Version 0.1 July, 2009
     * Copyright 2009 Ken Shirriff
     * http://arcfn.com
    IRsend irsend;
    int runitonce = 1;
    void setup()
      Serial.begin(9600);
    void loop() {
      delay(4000);
       if (runitonce == 1) {
       for (int i = 0; i < 3; i++) {
          irsend.sendSony(0x421, 15); // Sony Sound code
          delay(40);
          irsend.sendSony(0x1121, 15); // Sony Menu code
          delay(40);
          irsend.sendSony(0x1D21, 15); // Sony Enter code
          delay(40);
          runitonce = 0;}
      if (Serial.available() > 0) {
        char RemoteChar = Serial.read();
        //Serial.println(RemoteChar);   //for testing
        switch (RemoteChar) {
        case 'o':
          irsend.sendSony(0x5821, 15); // Sony Off code
          delay(40);
          break;
        case 'c':
          irsend.sendSony(0x82420, 15); // Sony Call code
          delay(40);
          break;
        case 's':
          irsend.sendSony(0x3121, 15); // Sony Source code
          delay(40);
          break;
        case 'n':
          delay(40);
          delay(40);
          break;
        case 'x':
          delay(40);
          break;
        case 'm':
          irsend.sendSony(0x7121, 15); // Sony Mode code
          delay(40);
          break;
        case 'b':
          irsend.sendSony(0x6821, 15); // Sony Back code
          delay(40);
          break;
        case 'g':
          irsend.sendSony(0x7221, 15); // Sony Glass code
          delay(40);
          break;
        case 'u':
          irsend.sendSony(0x6621, 15); // Sony Up code
          delay(40);
          break;
        case 'd':
          irsend.sendSony(0x2621, 15); // Sony Down code
          delay(40);
          break;
        case 'l':
          irsend.sendSony(0x5621, 15); // Sony Left code
          delay(40);
          break;
        case 'r':
          irsend.sendSony(0x1621, 15); // Sony Right code
          delay(40);
          break;
        case 'e':
          delay(40);
          break;
        case 'p':
          irsend.sendSony(0x7721, 15); // Sony PTY code
          delay(40);
          break;
        case 'i':
          irsend.sendSony(0xA21, 15); // Sony Display code
          delay(40);
          break;
        case 'q':
          delay(40);
          irsend.sendSony(0x1121, 15); // Sony Scroll code
          delay(40);
          break;
        case 'v':
          irsend.sendSony(0x2421, 15); // Sony VolUp code
          delay(40);
          break;
        case 'w':
          irsend.sendSony(0x6421, 15); // Sony VolDown code
          delay(40);
          break;
        case '1':
          irsend.sendSony(0x21, 15); // Sony 1 code
          delay(40);
          break;
        case '2':
          irsend.sendSony(0x4021, 15); // Sony 2 code
          delay(40);
          break;
        case '3':
          irsend.sendSony(0x2021, 15); // Sony 3 code
          delay(40);
          break;
        case '4':
          irsend.sendSony(0x6021, 15); // Sony 4 code
          delay(40);
          break;
        case '5':
          irsend.sendSony(0x1021, 15); // Sony 5 code
          delay(40);
          break;
        case '6':
          irsend.sendSony(0x5021, 15); // Sony 6 code
          delay(40);
          break;
        case 'a':
          delay(40);
          irsend.sendSony(0x1121, 15); // Sony Pause code
          delay(40);
          break;
  7. #97
    Jul 2006
    After much trial & error, this works pretty well. I prefer the built-in bluetooth in my truck over the Sony, so now I'm I'm working on trying to get it to send the mute code when I'm on the phone. The GMOS-LAN-012 adapter has a mute output, but the radio doesn't have a mute input. I'm struggling with what the code should look like when the arduino sees the mute (through a relay contact I suppose).
    Code:
     * http://arcfn.com
    IRsend irsend;
    void setup()
      Serial.begin(9600);
       delay(1500);
         for (int i = 0; i < 2; i++) {
          delay(40);
          delay(40);
          delay(80);
          delay(80);
    void loop() {
        case 'o':
          delay(40);
          break;
        case 'c':
          delay(40);
          break;
        case 's':
          delay(40);
          break;
        case 'n':
          delay(40);
          delay(40);
          break;
        case 'x':
          delay(40);
          break;
        case 'f':
          delay(40);
          break;
        case 'b':
          delay(40);
          break;
        case 'g':
          delay(40);
          break;
        case 'u':
          delay(40);
          break;
        case 'd':
          delay(40);
          break;
        case 'l':
          delay(40);
          break;
        case 'r':
          delay(40);
          break;
        case 'e':
          delay(40);
          break;
        case 'p':
          delay(40);
          break;
        case 'i':
          delay(40);
          break;
        case 'q':
          delay(40);
          delay(40);
          break;
        case 'v':
          delay(40);
          break;
        case 'w':
          delay(40);
          break;
        case '1':
          delay(40);
          break;
        case '2':
          delay(40);
          break;
        case '3':
          delay(40);
          break;
        case '4':
          delay(40);
          break;
        case '5':
          delay(40);
          break;
        case '6':
          delay(40);
          break;
        case 'a':
          delay(40);
          delay(40);
          break;
          case 'm':
          irsend.sendSony(0x1421, 15); // Sony Mute code
          delay(40);
          break;
  8. #98
    Mar 2004
    Cape Cod, MA
    I am not sure where this thread was last year when I was looking for information on this, but I devised a slightly different method for getting the App Remote to link up properly. I ripped open the faceplate of my HU, and found what was happening when you pressed the volume knob in. I discovered it was simply grounding out a pin on the circuit board. I then programmed an Arduino Nano with the following code:
    Code:
    int relayPin = 9;
    int led = 13;
    void setup() {
      pinMode(relayPin, OUTPUT);
    void loop() {
      delay(15000);
      analogWrite(relayPin, 255);
      delay(1000);
      analogWrite(relayPin, 0);
      delay(1000);
      delay(1000);
      while(1);
    I ran a wire from pin 9 on the Arduino Nano (I think there was a resistor somewhere too, will post a picture later). So when the car is turned on, the Arduino boots up, waits a few seconds, then "grounds" the pin in the HU, simulating pressing the volume button in. It presses it again to select the "Set App Remote" option and complete the link with the app on my Nexus 7. The only issues I have run into is if the volume or any other buttons are pressed before the link is made (steering wheel controls), it can change the menu on the HU, and mess everything up. Or if the BT connection is lost for some reason, I have to reboot the car, or the Arduino to get the link back (or pull the dash). I like the idea of the IR sensor, but have had good luck using my method.
    Edit: Here is an image of the Arduino: http://i.imgur.com/AOqwtqS.jpg
    Powered by the USB port on the right when the trucks starts. Pin 9 is wired to a resistor, which then goes to the transistor, which ground out the black wire which goes to a point on the faceplate of the head unit. Been working great for months, despite looking like crap.
  9. #99
    Mar 2015
    Looking at your tasker profile screenshots, it appears that you have it set up to issue the "Menu" code twice and then the "Enter" code twice in order to enter the App Remote mode. Based on your above reply, could a fully automated, hands-free solution be achieved by sending the "Source" code 7 times before sending the "Menu" and "Enter" codes?
    Apologies for reviving a dead thread but I'm trying to provide some insurance against having to take the dash-off to troubleshoot connection issues with the initial App Remote pairing with the Nexus 7. The ability to ensure that this connection happens faithfully on boot every time is key in making this interface as seamless as a regular double-DIN deck, and I don't want to have to worry about making sure that I remember to set the car to the correct input before turning it off in order to ensure I'll have automatic App Remote pairing via the Arduino IR commands the next time I start the car (I can see this happening if I am streaming music via BT, then use App Remote to listen to AM/FM radio, then turn the car off with the stereo in Tuner mode, as the button presses required are different as LastMile's post illustrates).
    Briang's method below also seems promising but I would prefer to not take the faceplate off of my brand new stereo. Briang, does your method connect the tablet to the AppRemote automatically regardless of what input the stereo is on initially at startup?
    Quote Originally Posted by briang View Post
    Thanks for everyone's help in this thread.
  10. #100
    Mar 2015
    Hi Lankin, do you still have the Timur's USB Rom, can you please send it to me i will pay for it... i have talk with Timur about this and he close the server download for 1st gen of Nexus 7.
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 12:49 PM
  2. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 09:49 PM
  3. 2001 tacoma install
    By rigg419 in forum Worklogs
    Last Post: 05-20-2007, 10:23 PM
  4. 2004 tacoma install
    By almanc in forum Show off your project
    Last Post: 12-03-2004, 12:43 AM
