Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 100
Like Tree3Likes
Thread: Nexus 7 Sony App radio Install Tacoma
  1. #31
    Oct 2013
    Quote Originally Posted by dlbogdan View Post
    Oh wait.. So you don't need to push the button to listen BT audio streamed? You only need to push it for the App Remote to work?
    Anyway I was thinking about a circuit that at power on to simulate pushing the button for a second.
    I need to know if it's possible to start the HU in the same time with pressing the button and then releasing or if it's important that you first start the car then after a little pause you push the button for a second.
    faheygf87, maybe you can test this..
    This is the draft circuit if it's not important to have a pause after starting the car. If it needs a pause then I'd have to build a pulse sequencer with two chips.
    Attachment 70394
    The HU has to be on for about a second before you can press the button, then it must be released in order to continue.
  2. #32
    Constant Bitrate Lankin's Avatar
    Jun 2009
    Can you explain to me what you mean by the remote jack? And how I would test this? Are you just talkng about using the remote control? I have never tried holding the enter button on the remote control to see if it would activate appmode. I'll try that when I get to my truck after work.
  3. #33
    Oct 2013
    Quote Originally Posted by Lankin View Post
    Its kind of irrelevant, the remote has to be line of site with the front of the HU. I tried using the remote with the N7 between the HU and the remote and it wouldn't work.
  4. #34
    Oct 2013
    Bucharest
    Lankin,
    You are gold! If that works somehow, I can build an electronics circuit to mimic pushing the button just after powering on so we'll never have to touch the unit again.
  5. #35
    Oct 2013
    Bucharest
    ... hopefully you have a wired remote (that's why I said "remote jack in the back of the unit") and not that wireless one. The wireless remote would be too hard to mimic with a circuit..
  6. #36
    Jun 2009
    Well I tried in just about every way to start appmode from the remote control with no success. I understand that there is a remote input on the back for steering wheel controls. Maybe it's still possible to send the input through that route.
  7. #37
    Oct 2013
    Good find, I hadn't even thought of that. My FRS doesn't have steering wheel controls but I think Metra makes an aftermarket add on SWC, maybe i'll give that a shot.
  8. #38
    Oct 2013
    Bucharest
    With my posts moderated for days before finally appearing here, the whole discusion gives you that "crazy" feeling when you read it. I think i'll just skip this forum and settle for some normal no paranoia moderation forum.
  9. #39
    Oct 2012
    Muscat, Oman
    Hi Lankin,
    Nice build After trying several options I'm also now looking at the Sony HU with App Remote as a solution for my 2006 Range Rover Sport. I probably use a Nexus also, but combine it with Tablet Talk to get better phone functionality, than what is offered by the Sony App...
    The question I've got though is how did you get the steering wheel controls to work?? Would be grateful for any advice in this regards
    Also, for anybody looking at doing this on a Jaguar, Land Rover product the level of work is significantly more due to the MOST system these vehicles use. Most importantly depending on which equipment level you have you will need to keep the OEM stereo connected and hidden away for the the MOST system to work. I think you also need to retain the amplifier if you have the high end stereo system...
    Cheers
    Guy
  10. #40
    Jun 2009
    Quote Originally Posted by Guyzer73 View Post
    Hi Lankin,
    I simply used one of these: Axxess ASWC-1 to hook up my steering wheel controls with the head unit. the head unit forwards the controls to the tablet via bluetooth.
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 12:49 PM
  2. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 09:49 PM
  3. 2001 tacoma install
    By rigg419 in forum Worklogs
    Last Post: 05-20-2007, 10:23 PM
  4. 2004 tacoma install
    By almanc in forum Show off your project
    Last Post: 12-03-2004, 12:43 AM
