Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 100
Like Tree3Likes
Thread: Nexus 7 Sony App radio Install Tacoma
  1. #41
    Oct 2012
    Muscat, Oman
    Quote Originally Posted by Lankin View Post
    I simply used one of these: Axxess ASWC-1 to hook up my steering wheel controls with the head unit. the head unit forwards the controls to the tablet via bluetooth.
    Thanks Lankin I actually found the same unit as they say it's compatible with the 2006 Range Rover Sport, but, not convinced due to the MOST system Land Rover use. I'll give it a try anyways and hope that my garage can work it out.
    Cheers
    Guy
  2. #42
    Oct 2013
    Just a little update from my end. I also used an Axxess swc, only mine was the universal add on one since i didn't have swc to begin with. It works okay, and gets me around but its not great. Reprogramming the buttons is an utter joke and resulted in just leaving them how they are in the default setting. I still can't access the app with my tablet but I can atleast cycle through the audio sources/change songs/volume etc. I'm still not %100 happy with it, but it is atleast functional.
  3. #43
    Feb 2007
    Bit of a thread revival, but I was going to do a very similar install to the OP in my MK1 Audi TT.
    The only problem I have is that here in the UK, none of the available Sony App Remote HUs have DAB - I could stream my favourite radio station by tethering to my phone, but the coverage isn't always great.
    So frustrating that everything is ALMOST there. I may have to drop SONY an email, but won't hold my breath.
  4. #44
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Hey dlbogdan - come back! Now you have enough posts. Did you finally build your "button Press" electronic contraption?
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #45
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    treetop you can read about dlbogdan's adventures in this post http://www.mp3car.com/show-off-your-...custom-hu.html SNO
  6. #46
    Sep 2006
    War-Town, GA.
    Oh! Thanks!
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  7. #47
    Feb 2014
    Well I tried in just about every way to start appmode from the remote control with no success. I understand that there is a remote input on the back for steering wheel controls. Maybe it's still possible to send the input through that route.
    I understand this may be a stupid question, but did you try holding the Sound button down for a few seconds? It seems to me I got the appmode to start after holding the Sound button down on the remote since it says Menu above the Sound button and pushing the Menu button (which is the knob) on the unit is how you start appmode in the first place. I think I had the 3100p and not the 4100p, so maybe it's different.
    Assuming that appmode could be activated via the Sony remote, it seems like an Arduino board could be used to clone the Sony remote. Once the Arduino board has the instructions to activate appmode, theoretically, you wouldn't ever have to touch the head unit again.
  8. #48
    Constant Bitrate Lankin's Avatar
    Jun 2009
    Quote Originally Posted by LastMile View Post
    Wow if you got appmode to work with the remote that's great! but for me, it just won't work. When I hold the menu (sound) button down on the remote it will wait, then beep and take me into the sound settings. I cannot get it to start appmode. Possibly newer models have newer firmware that allow this? Could you please post a video of you using the remote to get the unit into appmode? I believe if people see it, then the more arduino/programming people might be more willing to jump on with a solution.
  9. #49
    Feb 2014
    Again, if any of this stuff that I'm writing is stuff that you guys already know, I apologize. Go to your tablet's Bluetooth settings and find something like "Sony Automotive" in the list of available devices. Connect and pair the Bluetooth audio from the tablet to the HU. You should be able to do this without touching the HU assuming you have connected and paired to the HU via Bluetooth in the past. When you hold down the menu (sound) button on the remote, does it show "SET SOUND" on the display of the HU? If you keep hitting the down arrow button on the remote after holding down and then releasing the menu (sound) button, it should go through these options:
    SET SOUND
    SET DISPLAY
    SET BT
    SET APP REM
    Once it shows "SET APP REM", you press Enter on the remote, and the AppRemote app should connect to the HU from the tablet. I can confirm this works with the p3100 and the Nexus 7 2013 (both of which I have, but I can't speak to other hardware). Not only does this work using the remote, but I was able to record the remote codes from the Sony remote, and put together an Arduino that replicates this sequence. So now, when the car starts, power is supplied to the Arduino which is programmed to send the connect code to the HU and we never have to touch the HU to connect AppRemote. The HU can stay tucked behind the tablet. Let me know if this doesn't work for you, and I'll do the video demonstration. Also, I'm happy to post the Sony remote codes\sketch for any Arduino folks out there that want to build their own.
  10. #50
    Jun 2009
    SET SOUND
    SET DISPLAY
    SET BT
    SET APP REM
    ahhhhh thank you. I am working night shift now, but when I get off work I will try this. Yes, when I held down the menu(sound) button it did go to "set sound". I guess I was expecting to activate app mode right then so I kept trying that and gave up. I didn't even think about scrolling down through menu options. I'll try this when I get off work. And I would love to see a sketch along with the sony codes. That's awesome that you have already done this. Thanks for your input.
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 12:49 PM
  2. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 09:49 PM
  3. 2001 tacoma install
    By rigg419 in forum Worklogs
    Last Post: 05-20-2007, 10:23 PM
  4. 2004 tacoma install
    By almanc in forum Show off your project
    Last Post: 12-03-2004, 12:43 AM
