Page 15 of 15 FirstFirst ... 56789101112131415
Results 141 to 146 of 146
Like Tree3Likes
Thread: Android Mount in 2013 Altima
  1. #141
    Aug 2012
    Hello hexxamillion
    Thanks for your great threads, they have been very helpul and informative.
    Are you using a frontend for you car Pc?
  2. #142
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by theksmith View Post
    the bluetooth amp is a neat idea - i hadn't seen that before.
    lanzar makes a couple bluetooth 4 band half-DIN equalizers, i had considered getting one so i'd have fade control as well as the EQ, and the built-in BT simplifies wiring. they don't support APT-X though so i ditched that idea for now.
    It is but I think they should have taken it a bit further. The bluetooth only works with A2DP and HFP. So if you have your phone paired music will work through it but not phone calls. But that's ok because I have an idea for that later. I also found that my tablet (nexus 7) can't seem to see the amp so I cannot use bluetooth with my tablet. Again that is not a problem because the other cool thing is that is has RCA input.
    "Live Free!!!...It's all about Open Source"
    Current Proj:Android Mount in 2013 Altima
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  3. #143
    Dec 2007
    AZ
    Nexus 7 Mounted
    I was just too anxious. When the shop installed my amp I requested for them to run the RCA cable to the front so I can connect to the tablet when ready. I had to get an adapter to go from RCA to Jack which plugs into the tablet. Anywho..during my lunch today I did a test fit and found that I needed to make a minor mod to the mount to secure the tab a bit more. I installed the tablet and have it connected from the jack to RCA which is connected to the amp.
    This was how I spent my lunch time:
    This is it installed. I will share some other pics later. I plan to create a youtube video to describe my install a bit.
    This project is not complete yet. I am getting an accessory battery installed (Optima Yellow Top) along with my 12v USB hub. That is what I will be my source for charging the tablet and any other device with USB. I also have a mifi which works awesome with the tablet from my testing. I also have plans to install an aftermarket solution for handsfree since I will no longer have that feature. My factory radio had that.
    Stay tuned for more..
    Old Proj II
    Old Proj I
  4. #144
    Dec 2007
    AZ
    How ever did I forget to mention that I rooted and flashed my tablet with Lollypop.
    Old Proj II
    Old Proj I
  5. #145
    Dec 2007
    AZ
    New YouTube Video
    I created a new video to cover some topics about my install and a few other things.
    Old Proj II
    Old Proj I
  6. #146
    Dec 2007
    AZ
    YouTube Video about REAudio BT 900.4
    This is a brief video I made regarding the REAudio bluetooth amp.
    Old Proj II
    Old Proj I
  1. 2009 Altima Dash Mount Android Tablet PC
    By hexxamillion in forum Show off your project
    Last Post: 10-15-2013, 05:42 PM
  2. Replies: 91
    Last Post: 07-21-2013, 06:48 AM
  3. 2009 Altima In-Dash Android Tablet and System Upgrade
    By hexxamillion in forum Worklogs
    Last Post: 07-02-2013, 09:11 PM
  4. RR 05-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 05-15-2013, 08:58 AM
  5. Replies: 14
    Last Post: 07-28-2012, 02:20 PM
