Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 61 to 70 of 157
Like Tree3Likes
Thread: Android Mount in 2013 Altima
  1. #61
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    50 yrs. later...I finally rooted my Nexus 7. The drama ended up being my Windows 8 Pro 64bit OS. After days of trying on there I went back to my Windows 7 and was able to root just fine using the Wugs Nexus Root Toolkit. Now its time to customize...
    "Live Free!!!...It's all about Open Source"
    Current Proj:Android Mount in 2013 Altima
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #62
    Sep 2012
    I have a nexus 7 too can't wait to see how you customize your !
  3. #63
    Dec 2007
    AZ
    I just received my Lilliput 669GL with HDMI. This will be used with the MimicsX2 module to control my Galaxy S4 with. As I mentioned a few posts back this will serve as a secondary means for my mobile entertainment. My Nexus tablet is primary. The cool thing is this weekend will be pack full of adventure as I work on testing this MimicsX2 thing out. I have heard good and not so good things about it..but I prefer to have my own experience.
    Old Proj II
    Old Proj I
  4. #64
    Aug 2010
    Bahrain
    The only thing I don't like about the Nexus 7 is the screen brightness under sunlight, the 2nd generation is much better at this.
  5. #65
    Dec 2007
    AZ
    Quote Originally Posted by alawadhi3000 View Post
    Mine is pretty bright.
    Old Proj II
    Old Proj I
  6. #66
    Dec 2007
    AZ
    I successfully hacked open my lilliput, updated the firmware and connected the Mimics2X. Then I was able to pair it with my Galaxy S4. Not too shabby. Anywho. Over the weekend I will clean things up and put it back together with the Mimics module. Time to order some momentary switches. I need one for the tablet and one for the Mimics.
    Old Proj II
    Old Proj I
  7. #67
    Dec 2007
    AZ
    I only recently learned about the wireless hdmi adapters. I may try one of these. I will stay clear from the samsung all share one though. I read way too may negatives. Usually I dismiss them but this I will make an exception and look at a different one.
    Old Proj II
    Old Proj I
  8. #68
    Dec 2007
    AZ
    Second thought for this I will stick to the cables...
    Old Proj II
    Old Proj I
  9. #69
    Dec 2007
    AZ
    During my research this morning I found a solution for the hdmi connection from my S4. There are tons adapters available online that allow you to connect micro USB to HDMI. While that's all well and good the key for me is that the Samsung has a not so standard port so the MHL adapter I just purchased from my local electronics store has an additional adapter pin specifically for the Samsung smartphones (Note, S3/4, etc).
    Hey it works! This will simplify how I have to dock my phone also.
    This is the adapter:
    This is it in testing mode:
    Old Proj II
    Old Proj I
  10. #70
    VegasGuy's Avatar
    May 2009
    Las Vegas
    I was able to root my Nexus 7 (v2 2013) using the Wugs toolkit on Windows 8 pro 64. Unchecking "custom recovery" did the trick it seems. Unfortunately, NONE of the custom ROMS will load on the Nexus. Tried everything available on the CM site and the USBROM mentioned on another thread on this board. Nothing works on the latest Nexus, so far.
    Oh well, patience, I guess. Continue work on Centrafuse for Android while I wait for a stable ROM.
  1. 2009 Altima Dash Mount Android Tablet PC
    By hexxamillion in forum Show off your project
    Last Post: 10-15-2013, 05:42 PM
  2. Replies: 91
    Last Post: 07-21-2013, 06:48 AM
  3. 2009 Altima In-Dash Android Tablet and System Upgrade
    By hexxamillion in forum Worklogs
    Last Post: 07-02-2013, 09:11 PM
  4. RR 05-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 05-15-2013, 08:58 AM
  5. Replies: 14
    Last Post: 07-28-2012, 02:20 PM
