Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Like Tree8Likes
Thread: 2013 Camaro 2SS/RS... Mylink removed, I7 Mobile Project
  1. #41
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Glass work is pretty straight forward...mix to the directions..if its cold add a few more drops of catalyst....keep the fibers wet and use a roller where you can to squeese out the air...take your time and if unsure on the strength add more layers...just about anything can be glassed in...steel/ally...plastic..wood...foam...and just about anything can be used as a frame.i like alluminium as it never shrinks like wood..my dash/bezel shrunk just enough to create a gap...but only i can see it...once its done let it cure for a few days and start the bog work.smooth it over and give it a paint or just cover it..carbon fiber can be done just the same also..only problem is glasswork is really messy!!....
  2. #42
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Agree. And this makes it a little easier - SMD SunFlash UV Activated Polyester Resin; no mixing, a lot less mess! Just set the piece out in the sun and it cures in a minute or two, perfect, every time.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #43
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    This summer I am going to give the glass a try. I have another Metra kit for my Camaro dash, and I want to fit a 10" screen this time.
    I just hope that the Sunflash resin will stick to ABS so I can get a good fit.
  4. #44
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Just a quick update. I made a new cupholder, this time with dual USB 3 ports for faster transfers, added an Array Mic, Installed the HD Radio (waiting on an antenna amplifier), installed a Silabs USB radio, installed a mpcie BT4/AC WIFI card, moved the boot sector from the 256GB 2.5" SSD a 240GB mSATA SSD due to vibration concerns (the mSATA screws down to the motherboard), and optimized fast boot.
    I made a video showing it's current features with voice control in Driveline:
    protias likes this.
  5. #45
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Very nice Robert! The voice commands are worth the price of admission alone. Driveline certainly seems to be the next up and comer.
  6. #46
    Sep 2006
    War-Town, GA.
    Amazing!
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  7. #47
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I laser cut a new cup holder glow plate from 1/4" acrylic with 1/32" modified black acrylic top, and aqua LED's. I also added 2 USB 3.0 ports and a drop in USB Volume Control that also holds a touchscreen stylus.
    System test at night:
    protias likes this.
  8. #48
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Looks awesome rray. Do you even need a weather update being in freemont? Isn't it sunny all the time hehe SNO
  9. #49
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    haha! It IS always sunny here. When it finally rains, we call in sick, open the window to enjoy fresh cool air, and enjoy the sound of rain. It's a very rare treat. I even seen Hail once!
  10. #50
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    So I am trying to get better reception on my HD Radio. After burning through a box full of shekels, I cannot find a radio antenna that works well. I finally found the rear window AM/FM antenna connector, and it just happens to be directly above where I mounted my radio, but am not sure about the polarity of the connections.
    Here is what I found:
    Here is the window:
    So what say you?
    Do you think I can wire in directly from the antenna wires above to a Directed HD radio, and bypass 20 feet of antenna cable that are currently connect and not giving good reception?
    Or do you think there needs to be some kind of specialized isolation between the common connection of antenna and defroster?
    Or do you think I can try only connecting the side I marked + and not worry about the antenna shield?
  1. 2012 Camaro In Dash PC Project
    By rray in forum Worklogs
    Last Post: 10-01-2013, 10:53 PM
  2. 1967 camaro Project
    By sikryd in forum Worklogs
    Last Post: 08-16-2010, 12:38 AM
  3. Project Media-Z - 99 Camaro Z28
    By kiztope in forum Show off your project
    Last Post: 08-18-2006, 11:20 AM
  4. Project 'Uber-Hack Camaro' first boot in car!!
    By stealthy-one in forum Show off your project
    Last Post: 05-21-2006, 02:01 AM
  5. Project 'Uber-Hack Camaro' first boot in car.
    By stealthy-one in forum Worklogs
    Last Post: 05-18-2006, 07:41 AM
