Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: 2008 Lincoln MarkLT Android tablet install
  1. #31
    FLAC mauri's Avatar
    Jan 2004
    I have a vibrocell of an old Siemens C35 (see photo, with a 1 euro coin) really small.
    With a little imagination you could possibly use....
  2. #32
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by rray View Post
    I guess I'm luck at the micro surgery stuff. I would use a loupe on an optivisor and real bright lighting, then using a micro cutoff wheel in a mini Rotary tool to grind the whole power button off to access the smt pads underneath. Then solder with a 1/64th chisel tip.
    Sent from my SCH-I535 using Tapatalk
    Geez, I guess I know who to send the really small work to....impressive! I'd be lucky if I could see the power button at all.
  3. #33
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Indeed! Rray - the tablet is on the way..!
    I can almost see the smoke coming out the top of your heads for trying to figure it out . I appreciate it. Just took these pictures that show how much room there is once the bezel is put back together with the tablet and the climate controls right under it. Sorry for the crappy pictures, I need to get better acquainted with my camera. Also shown is the hole I intend to use to push the power button (which is right above the hole) if need be..
    There is barely ľ in space to work with..
    Hereís the pin engaging the power button..
    Iím not worried about it too much, I donít expect the tab to freeze or shut-down very often, if at all.
    Thanks for the suggestions tho.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  4. #34
    Sep 2006
    War-Town, GA.
    Well, I did a little tinkering this weekend since the sun came out and after all that snow (2 inch) here in GA. It was time to go outside and enjoy the warm weather (60 F).
    I think I said it before that Iím going to try putting the radioís faceplate in the ashtray; that requires wires to be soldered to the contacts to have a cable running between the faceplate and the body of the radio. No way can I do it myself, those contacts are to small but fortunately, my son is pretty good at soldering and said he could do it.
    I did a little fab to see if I could prove the concept and it looks like it could work..
    This here is chopping-up the ashtray compartment to make the faceplate fit
    So now it fits..(thatís the faceplate under all that tape).
    But hey, while Iím at it, why not motorize it! So I grabbed an actuator I had laying around and started fabbing to see if it would work..
    Surprisingly, it works!
    http://youtu.be/jufrz-ma3G4
    The only problem was that the actuator was too long so I couldnít let it fully extend so I bought one the proper size and just got it the other day..
    And after installing the shorter actuator, things work just fine. Now I can let it extend and retract all the way.
    http://youtu.be/Ck14oTKth4U
    Whenever I get the radio back from my son and it's really warn outside, then comes trying to mold the faceplate into the ashtray; and I donít have a clue how to do it yet..
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  5. #35
    Sep 2006
    War-Town, GA.
    That tablet has lots of ROM support:
    http://forum.xda-developers.com/gala...-3/development
    And best of all, you can connect a USB DAC for high quality audio if so inclined.
    Any DAC recommendations? I'm looking at ibasso D-zero or FIIO E7 (Fiio E07K new version) as an option to install along with the bluetooth audio built-in to the HU.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  6. #36
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I had a GS3, and burnt it out connecting an ODAC. I don't know for sure but I suspected my OTG cable and tossed it.
    The ODAC still works though, but was on the list with hifimediy sabre as compatible. I have both and the are clean noise free and cheap.
    -Robert
  1. Porsche Cayenne Android Tablet Install
    By reedickyaluss in forum Android Tablet
    Last Post: 11-22-2013, 11:17 AM
  2. 2008 Suzuki SX4 - Tablet Install
    By X3N1UM in forum Show off your project
    Last Post: 10-19-2013, 02:17 PM
  3. 2008 Chevrolet Corvette 7" Android Tablet Install
    By SDB_FTW in forum Show off your project
    Last Post: 09-02-2013, 02:23 PM
  4. **2008 VW GTI Nexus 7 Tablet install**
    By maresgti12 in forum Show off your project
    Last Post: 10-05-2012, 12:01 AM
  5. Android Tablet Install
    By rgscomputers in forum Android Tablet
    Last Post: 09-07-2012, 09:09 AM
