Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 2004 Ford Focus ZTS and Odroid U3
  1. #11
    Newbie focused's Avatar
    May 2014
    Canada
    Quote Originally Posted by blafrisch View Post
    First off, very nice project. I would love something similar in my car but have always been worried about the always-running PC draining my main battery. Have you noted how long it takes for the ODroid to drain your car's battery down to where the DC-DC USB will kick it off?
    Also, what I do for internet on my tablet (2012 Nexus 7) in my car is USB tethering. Setting up Tasker to auto-initiate USB tethering on the phone when connected to a PC/tablet is pretty simple and actually charges the phone rather than killing the battery in short time. Also I've noticed that it was more reliable than Wifi or Bluetooth tethering. I think what you need on the ODroid is to compile in the NDIS drivers if they aren't already.
    Looking forward to seeing a finished project and hearing more, good luck!
    Thanks blafrisch,
    I had thought about USB tethering, but plugging it in everytime seemed like an inconvenience (especially while driving). I have the Note 3 so the battery life is pretty solid, despite wifi hotspot. There's an NFC tag under the dash to turn on the hotspot, which is far easier.
    I'm not sure how long it will go before killing the battery. I didn't drive for a couple days this week. It turned over just fine when I started the car. Those were after hot days with the Cpu fan working pretty hard. The next time I have a driving hiatus I'll take a multimetre to the battery. I never did set the kill threshold on the converter, so it'll just keep running. Should probably get around to that one day.
  2. #12
    Sep 2009
    London
    Thanks for that post. I found very valuable information for my own project based on your component list. Here's my idea depicted and here's my post about it: http://www.mp3car.com/show-off-your-...odroid-u3.html
  3. #13
    Aug 2014
    What about screen resolution? Chalk has 1280x800, but odroid only can 1280x720 or 1920x1080. A little disproportionation or found workaround?
  4. #14
    Aug 2014
    What about resolution? Chalk has 1280x800 but odroid only 1280x720.
    A little disproportion or some workaround found?
  5. #15
    May 2014
    Canada
    The resolution seems to come in pretty clear without any workaround. I haven't noticed any blurriness.
    It comes in very sharp (I got glasses this week, so it comes in even sharper now!).
  6. #16
    Sep 2014
    Hi, I work in a similar project with the 7" chalk-elec display and Radxa-Rock board, how do you do to get multitouch?
    Thanks.
  7. #17
    May 2014
    Canada
    Hi hugovw1976,
    To get multitouch working was a three step process on the Odroid U3.
    1. Ensure you have the newest firmware (at least v. 1.5) for the Chalk screen.
    2. Enable multitouch for your screen by compiling the kernel with it enabled. I followed the steps outlined in the Odroid Magazine, Feb. 2014 edition. I'm not sure all the details for the Radxa-Rock, but I imagine it would be pretty similar.
    3. Place a .idc file with the vendor and product ID. Here is the Android .idc manual
    After you have those 3 steps, you should be good to go.
    Let me know how you make out.
  8. #18
    May 2014
    Canada
    I thought I'd give a quick update to how my carputer has been working over the last 7 months.
    Up until it started getting colder, all was working very well. The Chalk screen is holding up well, the Bluetooth OBDII connector never fails, the relays do as they ought to, and my volume knob hasn't failed me once.
    The only problem was that occasionally my Sure GPS would need to get repaired, for some reason it didn't want to automatically connect to the Bluetooth GPS app. That wasn't too big of a deal.
    Now that it's colder I have two problems:
    1. The battery in my car has a tough time starting the engine after a day of the carputer being on, with no activity. This just means that I have to shut off the carputer if I know that I'm not going to be driving for a day or two.
    2. The front left speaker occasionally dies out. It seems to be only when it's -5 - 2 C that this happens. It'll come back after the car warms up, but will intermittently keep on cutting out. I have a couple of possible causes:
    a. The cold makes it so that there is a poor connection somewhere inside of the TDA7850 chip, or causes condensation on the connection, grounding out the signal?
    b. Always using the ignition line (instead of the 12V) for power causes amperage issues, resulting in only one speaker cutting out
    c. I bought a cheap amp from Ebay, and the bitterness of low quality remains long after the sweetness of low price is forgotten.
    Other than that, the carputer is working well. I'd probably recommend going with a better quality amp for now, until I figure this situation out.
  1. Problem connecting OBDII scanner to 2004 European Ford Focus
    By ush1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-06-2011, 07:20 AM
  2. ford focus
    By bmbm in forum Newbie
    Last Post: 03-14-2008, 07:31 AM
  3. Ford Focus PPL
    By Phenetix in forum Power Supplies
    Last Post: 10-13-2007, 03:59 PM
  4. Does the Ford Focus (2004/5) play MP3 CDs ?
    By SAScooby in forum Car Audio
    Last Post: 02-15-2005, 04:57 AM
  5. Ford Focus MP3 Car PC
    By stevieg in forum Show off your project
    Last Post: 09-28-2004, 06:46 PM
Tags for this Thread
