Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Nexus 7 install into impreza
  1. #11
    Newbie gregthomas129's Avatar
    Aug 2014
    Central Kentucky
    Is this a 2012 version Nexus 7?
  2. #12
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Morning, I was wondering if you have tried Digtial Car for Android on your nexus setup and if so, your honest opinion on it? I'm developing it for the nexus 7 so I would love your views and how easy it is to operate etc.
    Thanks,
    Steve
  3. #13
    Aug 2014
    Central Kentucky
    Quote Originally Posted by D4VEW557 View Post
    One problem i am having is getting poweramp to start playing the music when i turn the power back on when i have the usb stick connected, it works fine playing from the internal file but not the usb stick.
    I have the same issue, but it works if the drive stays powered. I'm getting ready to install another separate, always on power supply to power the hub and usb drive.
  4. #14
    Mar 2009
    Hi Fellas, thanks for the comments.
    Its a 2012 Nexus.
    The u channel came from a diy shop although i would imagine its available from many websites.
    I'll try keeping the drive powered and see if it works.
    I have tried digital car and my honest opinion is its good and credit to you for your work. i recently had a go at making an app and after two days of work i had created an app that when you click a button it displayed hello on the screen, its a hard thing to do so i applaud you for your skill.
    Back to your app though the reason i don't use it is it's not customisable enough for me something like centrafuse for android where the core program is there and you can create your own skin with some basic computer knowledge and then just load in.
  5. #15
    Aug 2014
    Central Kentucky
    There's a 4.4.4 rom available for the 2012 nexus 7 called autodroid specifically for car installs. You can get it here: http://forum.xda-developers.com/show....php?t=2789993 I've been using it in my setup for a while now and it works pretty good... and it has current support.
  6. #16
    Mar 2009
    It looks ok but i don't see any good reason to loose all the work i have done with timur's rom. Is there any big advantages to this other than it's based on kitkat rather than jellybean.
  7. #17
    Aug 2014
    Central Kentucky
    The biggest reason I use it is the customizable navbar. You can add up to 10 buttons including volume and media controls and also a power button. Its very handy to have those buttons while in other apps without having to go back to the home screen. Also the shutdown options allow you to set a video to be played at shutdown. Also, there is current support instead of being abandoned like usbrom.
  8. #18
    Aug 2014
    Central Kentucky
    Poweramp with customized navbar.
  9. #19
    Mar 2009
    All valid points. I currently use go launcher in full screen mode so I don't have a nav bar but of it was customisable then I would consider having one rather than going full screen. Have you had any problems with using it such as any incompatibility issues with apps. System crashing or locking up.
  10. #20
    Aug 2014
    Central Kentucky
    The only issues I've had is if I install the noozeoxide dsp app it doesn't want to wake up after sitting for several hours and I can't seem to get the built in dsp app to work. Other than that I've had fewer problems than when I used usbrom.
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 11:49 AM
  2. My nexus 7 install
    By pjoseph in forum Fabrication
    Last Post: 02-09-2014, 04:00 AM
  3. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 08:49 PM
  4. 2006 Impreza Install
    By secretagentman in forum Newbie
    Last Post: 06-29-2006, 08:49 PM
  5. subaru impreza install
    By formadmenonly in forum Show off your project
    Last Post: 08-05-2004, 02:22 AM
