Results 1 to 10 of 20
Thread: Nexus 7 install into impreza
    Mar 2009
    After wanting a carpc for a long time i started making a centrafuse skin of my own in fact i ended up making three different ones and i must say i had a lot of fun doing it also it was a great learning experience.
    When that was done i set about building the pc i got as far as mounting the mother board and cpu and then i started to get tempted to go the android route.
    After my missus offered to get me a nexus 7 well then the deal was sealed android it was.
    I have tried a few incar app such as carhome ultra and found them all to be good but none of them were visually what i wanted so using a combination of apps and launchers i'm happy with what i have created.
    The setup is pretty standard for incar.
    Nexus 7
    USB rom (hats off to timur's kernel)
    OTG cable
    Homemade mounting (chopped up double din ford head unit)
    Alpine head unit (may be replaced with a usb dac in the future)
    Main APPs used
    Go Launched
    Desktop visualizer
    Poweramp
    Google Maps
    Google Navigation
    Tablet talk (combined with my parrot hands free kit)
    The whole setup is now ready to fit in the car as i got the last few bits i needed but typically i don't have my car for the next few days.
    Anyway here are a few shots of the unit not in the car obviously.
    This is one of the screens (ignore the to icons in the top left they will be removed)
    A shot of the rear. Here you can see the OTG cable the cable that connects to the head unit and a 3amp DC DC convertor. Also as room is tight i had to relocate the usb and audio sockets from inside the tablet on to the back this can be seen in the middle.
    Another shot of the rear with the cover on
    Side view
    This is how it will sit with the head unit
    When its installed i will try to get a video of the system in action. There is more to add such as cameras but that will be once i am am happy the basic system is working.
    Jun 2014
    add info
    Where did you get the enclosure the nexus is mounted to? Doing the same sort of thing but with an odroid computer plan on using it along with a head unit like you are cheers very interested
    Sent from my To Be Filled By O.E.M. using Tapatalk
    Mar 2009
    I made it. Its a old double din unit that I chopped up to fit and a couple of pieces of aluminium u channel to hold the nexus in place. I will have it to bits later today so I'll get some photos for you.
    Jun 2014
    Ok thanks was thinking of one of the lilliput mounts but not sure if it would be suitable.
    Sent from my TF600T using Tapatalk
    Mar 2009
    maybe not, but could be adapted to fit depending on how thick the lilliput is i suppose
    With the tablet and one rail removed
    The nexus fits nice in the channel
    Mar 2009
    One problem i am having is getting poweramp to start playing the music when i turn the power back on when i have the usb stick connected, it works fine playing from the internal file but not the usb stick.
    Jun 2014
    Sorry I don't use poweramp so cant help with that.
    Newbie gregthomas129's Avatar
    Aug 2014
    Central Kentucky
    Nice install! Is this a 2012 Nexus 7 or a 2013?
    Aug 2014
    Central Kentucky
    Also, where did you get the u channel?
    Aug 2014
    Central Kentucky
    Nice install! Is this a 2012 version Nexus 7? Also where did you get the u channel?
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 11:49 AM
  2. My nexus 7 install
    By pjoseph in forum Fabrication
    Last Post: 02-09-2014, 04:00 AM
  3. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 08:49 PM
  4. 2006 Impreza Install
    By secretagentman in forum Newbie
    Last Post: 06-29-2006, 08:49 PM
  5. subaru impreza install
    By formadmenonly in forum Show off your project
    Last Post: 08-05-2004, 02:22 AM
