Results 1 to 10 of 19
Thread: 2010 Jetta - NUC based Car PC
    Nov 2013
    Bay Area
    So I started this project quite a few months ago. Right now I have the following components in the configuration:
    Mobo: Intel NUC D34010WYK
    PSU: Mini-box DCDC USB
    AMP: TDA7850
    Volumn Knob/Home Button/Fan Control: Arduino with some custom circuitry
    After I realized there's no existing enclosure that would work perfectly for my setup, I decided to design one myself and 3D print it. I know that may sound too much effort but I want to take this as an exercise. Currently the design is about 50% done:
    And it looks like this in real life:
    I use the rocker switch to simulate an IGN signal, and the system boots and shuts down as expected. The amp works OK, but it picks up noise from the PSU/NUC even when I leave the audio input floating. I am not sure it's ground loop noise or not but I will try to get both a ground loop isolator and a power noise filter to play with and see how things go.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Very nice work! I will be following this thread. SNO
    Nov 2013
    Chicago Suburbs
    cool!! nice job... Amps like that are always finicky
    Nov 2013
    Bay Area
    Hi Jeff, do you have any experience on fighting these noise problems? I am still waiting for my ground loop isolator and power noise filter, but I would like to learn what people usually do with it.
    Nov 2013
    Chicago Suburbs
    What Isolators are you waiting for? Also where are your audio lines in the photos?
    I am thinking the first thing I would do is try to isolate audio lines and then I would move the amp away from the box (for testing purposes). try a metal shield around the amp ( Careful not to short it)
    Ground the shield ad try with out grounding.. see if those things help
    Nov 2013
    Bay Area
    Thought it may be a good idea to share more details with you guys, and let me start with dash trim.
    I actually bought a Lilliput 669 and replaced the touch screen with a capacitive one, but end up I found myself not satisfied the rather low resolution, and bought a better one with native resolution 1280x800. The new problem is that it's not going to fit any aftermarket dash trim. So beside the enclosure, I went ahead and started design my own dash trim as well.
    This task isn't trivial because, as we all known, many dashes are not flat surface. Although this is a hobby project I want to make it as good as I can. So I ended up tried to imitate the trim of the stock radio by taking multiple sample points (for both depth values and locations of boundaries) of the surface:
    I reconstructed the curved surface with some mathematical tools and wrote a couple plugins for SketchUp, and successfully modeled the trim piece in SketchUp:
    Of course this is far from finished. I still need to make cutoffs for the display, volume knob, home button, think about how to hold all these things tight to the piece, and how do I attach this to the enclosure (if you look at the enclosure design above I did reserve some M4 screw holes for this). Also FDM 3d printing is far from ready for this kind of work: printing size limitation, quality of the product surface, etc. I will need to glue multiple pieces, sand and paint before I have an usable dash trim. Below are some test prints I made to verify the model:
    Nov 2013
    Bay Area
    Quote Originally Posted by -=Jeff=- View Post
    I ordered these two guys from ebay:
    http://www.ebay.com/itm/270483867810
    http://www.ebay.com/itm/131172493407
    Please see this picture:
    Actually I kind of confirmed that a major part of the noise comes from the power source, which the AMP and the PSU (for the PC) share:
    - Even when I unplug the aux cable to the AMP and let the input floating, the noise is still there
    - If I use a separated 12V power source for the AMP, the noise will be gone. The AMP still sits next to the running PC.
    That's why I want to see whether a power noise filter will help. I guess the CSS-100 thing is nothing more than an usual DC noise filter we see in many DC power cables, with higher current rating though:
    A dedicated power rail from the AMP all the way to the battery may be a better solution, but I want to experiment with various solutions.
    Thanks for these useful tips. I will try them and see whether they will improve the output.
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Very nice!! What are your plans for the arduino?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Subscribed....very interested to see the final product. Looks good so far!
    Nov 2013
    Chicago Suburbs
    I used a ground Isolater like you did for my tablet install. I was getting alternator whine and that seemed to clear it up (mostly) for me
  1. jetta golf6 after 2010 dashboards
    By obdelectro in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-21-2011, 01:30 AM
  2. JETTA MK II. The second console im doing for a jetta
    By Jetta_Kris in forum Fabrication
    Last Post: 07-12-2007, 07:01 PM
  3. Hardware based players (Not PC based)
    By andrewc in forum Newbie
    Last Post: 05-31-2005, 03:36 PM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
