Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Enforcer
Thread: 2004 Jetta Sport Edition - Windows 8.1 Tablet CarPC
    Apr 2015
    Hey guys!
    Just a quick little bit about me, I'm from Hamilton Ontario and have done a fair amount of work in car audio and alarm systems in the past. I've been thinking about doing a CarPC build for awhile now and after doing some research I've decided to go through with it!
    At first I was planning on using an old laptop with a broken screen and putting an SSD in it, when I found a a 7" tablet for an unbeatable price. This would also make it simple to have the tablet be remove able from the car.
    The tablet I've decided to go with is a Hipstreet W7 Windows 8.1 tablet, for a front end I've decided to use Centrafuse. Currently I've installed MapFactor Navigator and a basic OBDII reader.
    I've also purchased a Vantec 7.1 USB Sound Card (NBA-200U), the front and surround outputs will connect to a 4 channel amp for my door speakers, the center/sub will run to the mono block amp and drive the subs. I'm planning on running a 3.5mm audio cable from the line in connection and having a female end in a button blank located above the tablet to use as an AUX input. I'll also run a small microphone to the map lights for use in phone calls
    Laying around I had a Microsoft GPS-500 USB GPS that I'll use alongside MapFactor's Navigator
    Lastly, a 10 port powered USB hub to run all my devices and hopefully charge the tablet
    To Order:
    OBD II Reader, unsure if I want to pickup a basic one, or purchase a Vagcom from Ross Tech.
    I'm thinking about 2 webcams, 1 to act as a dashcam and the other as a reverse camera
    I've got a running list of what I've purchased, the price I paid for them, and where I got them in a good docs spreadsheet located here: Click Me!
    I'll be updating it tomorrow with some of the things I haven't included yet.
    Sep 2013
    Sydney Australia
    Kudos for the thread. The attachments do not work for me so I cannot see what you are trying to show. I am curios, are you using a tablet or a laptop? If you are using a tablet, how do you sync up so many peripheries?
    Apr 2015
    Quote Originally Posted by nick300zxtt View Post
    I'll fix the images when I get home from work, they did work when I previewed the post.
    I found a 10 porn usb hub that would allow me to plug all the peripherals into it, they jey is that its a powered hub so its not relying on the small amount of power from the tablet to run them all. This also means that I'm going to have to find a way to run both the tablet charger and the powered USB hub from the car battery
    Sep 2013
    Sydney Australia
    pics are fixed. they are worth a thousand words
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You can use something like this to power that hub and you could add another to power your tablet if it takes 5v as well Good luck SNO
    Apr 2015
    I've gotten a few more pieces to my build over the last 2 weeks
    Alpine V-Power MRP-F240 4 channel amplifier for my door speakers:
    Pioneer GM-3500T 2 channel amplifier that I'll bridge and use for my sub(s)
    A micro USB to 2 USB A Male spliter; the mico usb end will connect to the tablet, the black "data" end to the USB hub and the red "power" end to the charger
    Lastly, an AVerMedia AVerTV Volar Hybrid Q TV/Radio Tuner; it has a coax input and came with a small coax antenna, the antenna works just not very well I'm hoping I'll be able to cut the end off my car antenna and crimp on a coax connection
    Now I need to plan out how I'm going to actually mount the tablet in my dash while having it both sturdy and removable
    Jun 2015
    Italy
    Where did you buy that usb splitter? Does it work? I have the same problem: my tablet has only one micro usb input and I need to connect an external hdd while charging the tablet...
    Dec 2014
    Canada
    I have very little experience with Windows tablets. Can you please explain what's involved in getting Centrafuse installed on one?
    Sep 2014
    Quote Originally Posted by thedivision View Post
    It's the same as with a windows desktop, the only thing you'll need to do is change the resolution once it's installed
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by TamFire View Post
    I found a 10 porn usb hub that would allow me to plug all the peripherals into it, . . . . . . . . . . . .
    Kinky.
    And I didn't even have to misquote it.
  1. 2004 VW Jetta GLI CarPC and more
    By cazzz in forum Worklogs
    Last Post: 12-31-2014, 12:48 PM
  2. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 01:55 PM
  3. windows xp tablet pc edition on car computer
    By mxl4729 in forum Software & Software Development
    Last Post: 04-30-2008, 12:53 AM
  4. Microsoft Windows Media Center Edition 2004
    By srcstc in forum Software & Software Development
    Last Post: 06-16-2004, 03:05 PM
