Page 29 of 56 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 553
Thread: 95 Lexus SC300 - 0l33l's "Project SC300"
  1. #281
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Windows XP installed without a hitch. Going to put in my fx5200 and audigy2 and reformat tomorrow.
    What is left:
    making case for PSU + Hd out of the cd changer
    case for motherboard
    BTW: The maxtor drives have a very nice shock resistance rating. link
    60G operating, 300G nonoperating
  2. #282
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by 0l33l
    Knowing my uncle, that is a lot of work
    We ran the power wires at the meet... remember?
    No, I decided to stop watching how everybody were working on your car while you were polishing a brand new amp in the back of the car...
    Anyhow, you already have both (+) and (-) wires ran through and fused?
    What about the distro block... Did you already screw that into the trunk somewhere?
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  3. #283
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by DJiK
    Well, we've only got the + wire run. But the negative should be easy since it should be as short as possible. The + wire is not fused. Neither is the dist block. And its not screwed in yet either.
  4. #284
    Jul 2004
    Berkeley, CA
    Ah ****! I just realized that I can't swap my videocard because then I'd loose dual monitor support on my development machine
    So... anyone have a nice videocard they wanna sell me for $35?
  5. #285
    Jul 2004
    Berkeley, CA
    Today's progress:
    I got the 16ft Xenarc extention cable.
    Car is in shop and I'm $750 poorer Car is getting new rack and pinion steering since mine is leaking, and 2 new shocks because one of them died. Atleast this will fix my steering annomalies. Plus I opted for some kyb shocks up front instead of the stockers.
  6. #286
    Spring Hill, Florida
    Just when there was some progress! What is your grandfather making the mold out of? Fiberglass?
    2005 Black Chevy Impala
  7. #287
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Shelbrain
    Yeh, but the car will drive better. The steering was quite sloppy for a while. This should fix that problem, plus make the car stiffer.
    Mold was out of cardboard boxes. He then turned that into thin wood, and we test fit it and cut it some more. So basically we now have a wooden peice that fills the whole driver's side rear quarter panel. The amps are getting mounted at around a 25-30º angle. I'd have the pics, but the camera is in my trunk at the shop
  8. #288
    Jul 2004
    Berkeley, CA
    Progress:
    Car definately drives better. Steering wheel returns to normal position. No more bump steer. Steerign wheel stays in place. Overall happy with new handleing.
    Now for the pics:
    Testing out area.
    Cardbox template
    Complete wooden template
  9. #289
    Jul 2004
    Berkeley, CA
    Stock components
    Stock sub
    Stock speaker and mystery box
    And yeh, you can see the gas tank.
  10. #290
    Jul 2004
    Berkeley, CA
    Arrow CD Changer
    Fully assembled.
    Closed.
    No cover.
    Lots of screws.
    Gutted or not?
    What's on the inside now?
    DSATX and Maxtor 160gb test fit...
  1. '95 Accord Carputer Project
    By Gewehrschuss in forum Show off your project
    Last Post: 12-30-2005, 09:51 PM
  2. Project lexus ES300 with 300 or so pics
    By mlazzaro@excite in forum Fabrication
    Last Post: 01-02-2005, 09:48 PM
  3. Lexus SC300 Carputer 1.0
    By bigmonkey70 in forum Show off your project
    Last Post: 04-06-2004, 10:39 PM
