You hook up USB and then hook up the AC into the terminals (wiring diagram somewere in this thread). They use a PIC18f2455 which I'll probably upgrade to an 18f4455 later because it has more I/Os.Originally Posted by Cris
How are they gonna work?
Originally Posted by 0l33l
Ok, now in English please...0l33l
Ok. This is a USB Relay controller with isolated inputs/outputs. Its USB because it uses the PIC18f2455. It is based on Curiosity's Cario design. If this board is successful, then I plan on using the PIC18f4455 which ahs more I/Os (inputs/outputs).Originally Posted by Cris
What this board is going to be used for: Digital A/C controls. My A/C controller in my car is good, but the problem lies in the dead screen. Plus its not the prettiest. I wanted to move my LCD up... I don't want the shifter getting in the way. So with this board I'll be able to control the A/C without actually touching the A/C... its going to be getting the same signals as if I was touching the front of the A/C controls.
Besides being used for A/C... I'm planning on using it for the volume knob since it has an analog to digital converter, so I can hook it up![]()
This is my first post, and it's because of your project that I finally felt the need to get an account and speak! I also have a Lexus and have been looking into doing a flush mounted touchscreen as well, but have always been frustrated with the limited space because of the AC controls. The factory navigation system integrated the AC controls which saved a ton of space. What I'd like to do is replace the AC / Radio with a 7" touchscreen up top followed by a slot load CD / DVD burner and finally have a Griffin PowerMate protruding at the bottom. Haven't even measured to see if this would fit or anything like that, but that's my dream.
Which brings me to my question... how in the $%^& did you figure out how to get the PC to control the AC? I've had some basic electronics courses (none involved with programming chips yet), but never would have thought to tackle that goal. Do you think the board you're making for the SC would work on the GS? If not do you think you can point me in the right direction to accomplish this goal myself? Thanks in advance, and keep up the good work!![]()
2000 Lexus GS300 - MP3Car Newb - Project in the works! (both Carputer and single turbo 2JZ-GTE)
you should mass produce them to the other 2 sc owners on here lol
i got dat ***** sittin on 22s! SUPERMAN EDITION!
I'm guessing that the board will work for the GS. Should actually be more functional, as i still have to set my climate through the knob (although more intuitive).Originally Posted by GS300t
Once I get the problems worked out with the board (for instance it looses USB when I restart), then I will produce them. Not mass produce... so I can keep the prices astronomically high...![]()
Ouch, the beautiful free market economy... haha I was looking into the problem a little more and digging through some old threads and found the one on Phidgets, which I would think I could get working with my climate control. Maybe I could use the 0/16/16 model with the 16 outputs controlling all of the buttons, but 16 inputs may not be enough (or even sensitive enough for that matter) to decipher what the LCD is outputting. If that even makes sense? I'll have to wait until I get my car back here soon and start probing the LCD to see what it'd take to read it directly into the computer. Sounds like a heck of a task, but one I'll gladly take on! I'll let ya know how it goes...Originally Posted by 0l33l
One reason I did not use phidgets: they are not isolated. That can be a problem because the CC in my car shares grounds.Originally Posted by GS300t
BTW: What I said was a joke. I'd sell the thing as a kit, as it takes me forever to soder by hand.
Also, are you on clublexus?
What do you mean by they are not isolated? I'm probably just completely missing what you're saying, but I would think if the CC is sharing grounds then isolation wouldn't be a problem? I think I may have just confused myself, so if you can clarify what you meant that'd be a huge help to me! hahaOriginally Posted by 0l33l
I know it was a joke, I was just goin along...And yes, I'm on CL with the same username, GS300t.
