So are you saying there's no isolation on the outputs or the inputs of the Phidgets? Not sure how you were thinking about doing it, I may have been thinking about doing it the opposite way or something. The outputs on the 0/16/16 model have their own ground, so I planned on running each switch or button through the outputs to have them activated through the touchscreen, then having the inputs which share a common ground on the Phidgets read the LCD output to get an accurate reading on where the CC stands. Make sense? I still may just be thinking about this all wrong, so correct me if I'm just way out of line! I'm just guessing based on pictures right now since my car isn't around to look at or probe on.Originally Posted by 0l33l
LinkBack URL
About LinkBacks
And yes, I'm on CL with the same username, GS300t.
Damn it, back to the drawing board... which I don't even have one of yet. Just rollin the ideas around in the ol' noggin, but I suppose I should wait and see what I've got to work with in the car before tryin to design some sort of circuit.
Well thanks for your help so far, it's definately gotten the thought process goin!
