Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 57
Thread: JC-S60's ...erm... S60!
  1. #21
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Yeah, I know
    Was planning on a volume-knob earlier, but haven't had too much time. I could use the volume-knob from my original hu, and maybe add some buttons... later
    Now I want to get everything working like nav, radio, etc... also need the hardware to be developped some more (case, cables...)
  2. #22
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Check out sysmetrics for info on your system. I use it all the time, and its skinnable, so you can integrate it with your choice of player.
    http://www.xymantix.com/
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  3. #23
    Mar 2004
    Ghent - Belgium
    That seems a very nice program!
    Thanks, I will look into it.
  4. #24
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah look sweet, might give it a go when i get home.
  5. #25
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    hey did you ever get anymore pics there JC?
    肚子笑痛了
    S60 Install
  6. #26
    Mar 2004
    Ghent - Belgium
    Not yet... I have pics, but more of the same...
    Just have to resize them and put them on-line sometime...
    Just saw you bought an awesome car man! What engine does it have?
  7. #27
    May 2003
    Miami, FL
    yeah I love this car, i've never had anything this nice before. It's the 5 cylinder gasoline, so now i'm on the hunt to find a double din panel to replace the radio. But I want to try to keep the popout cupholder to the left of the radio. I have to find out if mine has a stock amp or if everything is done from the radio. I only have speakers in the front and rear doors, so I assume that it does not have a amp.
    肚子笑痛了
    S60 Install
  8. #28
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Great job!
    Really like the custom dashpanel. And of course, nice car. Like today's designs of Volvo very much.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  9. #29
    Mar 2004
    Ghent - Belgium
    @jcdillin
    Nice engine, that one! You could try to keep the cupholder by cutting the double-din panel and putting the cupholder next to it.
    I think that should be possible. As far as I can remember, there should be enough space.
    The stock amp is placed under the front passenger's seat, but you will have a hard time using it, because it is positive ground! You can try and use a ground-loop-isolator though...
    @proTONEd
    Thanks! In fact, since volvo has looked a bit at audi for its design, a lot has changed
  10. #30
    Tainted Love Cris's Avatar
    Romania
    JC, awesome work on the dash!!! Maybe you could place a DVD drive mounted horizontaly on the left, although I'm not sure it would look right. Awesome car, and incredible setup.
    Will you get it tinted?
