Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 81 to 90 of 111
Thread: Clean GTI VR6
  1. #81
    Jul 2004
    This is the best stealth LCD install I have ever seen!
    Did you use this basic stamp discovery kit (Click here). You also said that the original servo was not strong enough to flip the screen and or hold the weight of the LCD. Can you explain what you mean by "metal geared servo" in which you used to sovled those problems?
  2. #82
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    he does have a link to his stamp kit on one of the pages.
    As for the metal geared servo it is a servo with metal gears! What else would it be???
    ie plastic gears replaced by metal ones so they don't strip as easily under heavy load. You can buy them with metal gears or sometimes buy metal gear kits. You can even buy them will ball bearings or replace the bushes with ball bearings.
  3. #83
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Dude, it looks awesome! I wish I had a screen at all and then the time to make it look that good. I am left with my own front end that runs off voice till I have the money for a touch screen. Keep up the good work!!
  4. #84
    Constant Bitrate blackbravo's Avatar
    Nov 2004
    Southampton, UK
    Top work mate looks real good, how far of complete are Ya?
    Loving the screen
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
  5. #85
    Constant Bitrate john_draws's Avatar
    Jun 2004
    hey all thanks for the post, scouse u were close on my situation. I rolled off the couch and couldnt get up so i bought myself a life alert system. I m thinkin about buildin gps into my life alert so they can find me were i fall.
    Blackflux i think scouse answered your question for me and everybody else thanks for the kind words.
    I am still workin on the case and *** far as ventilation i think i have that more than covered with 2 full size fans . see attach pic
    hopefully tonight i will have finished pics of the case although i am feelin awfully
    lazy today.
    so till later tonight
    late
  6. #86
    Jun 2004
    oh ya woops blackbravo i would say im about 60% done with the origanal project. I still have the case to build and i am making blind spot cameras in my car.
    The cameras will go in the side view mirrors plastic housing then i have 2 2.5" screens that i will either put on the A piller or flush mount it into the door.
    well why i am on this topic i was wondering if somebody had an idea of how far i can extend the conroler board (board with the control knobs) from the screen.
    I thought that i read somewhere that u can not extend the board to far from the sceen. but i dont know so i thought i would throw it out there.
    all help apreciated
    pic is of 2.5" screen ripped from xbox a controller
  7. #87
    Newbie Projectwidow's Avatar
    Apr 2005
    Suwanee, GA
    that is looking very good man! i cant wait to see the final product!
  8. #88
    Jun 2004
    Projectwidow thanks for the comments, I have so damn things i want to do its hard to keep everything straight. I got what you call "scatter brain" so I have more ideas then knowledge or time.
    Anyways im hopping someone can help me out or give some opions real quick.
    The delema is that the case is pretty tight to fight the opus and desktop hard drive in it. I have a 40 gig laptop drive that fits no problem but it is to small data wise.
    So my questions are this
    1. do you think it is a bad idea to have the opus actually sitting and
    touching a peice of plexi...(see pic 1 opus )
    2. the lower shelf is a 1/2" above the via processer fan and chipset heat
    sink. DO you think that is enough breathing room for the board?
    (see pic 2 clearance)
    3. Would the hard drive sandwiched between pieces of plexi cause a big
    heat issue? (see pic 3 sandwich)
    What my ideas are behind this set up.
    1. I want to seperate the heat of the hottest components from the
    processor and chipset...(opus and hard drive) <---Hottest pieces
    in the case.
    So im going to put a plexi shelf above the motherboard and on that
    shelf it will house the hard drive and opus. Which will have two
    80mm fans blowing directly on them with a exaust fan out the back.
    2. Basically I am bankin on VIA and there low heat board be able to
    operate with out any direct fan blowin on it, It will be ventillated
    though. Like i said the real heat is the hard drive and power supply
    So i figure i will isolate that heat and hope the via can do its thing.
    So with that any quick help or suggestions on the 3 questions would be much appreciated. It is just sitten in front of me cause I cant make up my damn mind. HHHEEEELLLLLPPPPPPPPPPP
    thanks to all responding in this thread
  9. #89
    Constant Bitrate grum's Avatar
    Feb 2005
    australia, melbourne
    Quote Originally Posted by john_draws
    in the case.
    ok 1 - i dont think touching plexy is a prob - its an insulator so meh...
    2 - **** off the graphics card or whatever is making the plexy box so tall. and throw in a smaller card. and cut it down. remove the power from the plexy alltogether and throw it in another fanned box. with or without the hdd.
    3 - yeah i would at least give it a few cms for the air to move away from the hdd.
    otherwise nice install... keep us updated.
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
    new carpc finished, thinking of way to mount HDD
    and not installed yet.
  10. #90
    Mar 2004
    Bristol
    no probs dude. if you want to send me a link to your webcam i will check up you every once is a while (well when i am feelign horny and want to see a fat naked guy - ooooo baby! hehe)
  1. Worklog: Wasabi's 2001 VW GTI VR6 Carputer
    By Wasabi in forum General Hardware Discussion
    Last Post: 10-08-2005, 02:11 PM
  2. 2004 VW GTi VR6
    By TurboBmaNN in forum Show off your project
    Last Post: 01-03-2005, 06:07 PM
  3. MK3 VR6 Custom dash questions.
    By Monsta in forum Fabrication
    Last Post: 07-30-2004, 06:19 AM
  4. GTI PC Up and Running!!
    By Nanozic in forum Show off your project
    Last Post: 07-21-2004, 12:10 AM
  5. 1998 VW GTI VR6 Project
    By Stavros in forum Show off your project
    Last Post: 01-27-2003, 12:16 PM
