Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
Thread: '00 accord p4 mobile
  1. #11
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    yeah the case is going in the trunk....wish it has a specific space back there.....but it really doesnt.....just gonna be mounted to the floor with angle brackets....off to the side.
    PC Components:
    My work log
  2. #12
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    yeah, i need to add another fan blowing out hot air from my carpc... my Via M10K CPU temp sometimes hits 150F (78C) when using Map Monkey GPS or watching videos (which causes random PC lockups, not fun!). Is there anyone else here having this problem?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  3. #13
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    That case looks cool. Keep us posted on the LCD install. I like the idea of being able to snap it in and out.
  4. #14
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    What about me!? I built half the **** in that car, lol. and I'm the one who bought the "marine grade grille." I think the system would be alittle nicer if RoadRunner didnt lock up so much...lets install the system reset switch sometime.
    -your brother
    And to clear some confusion, I dont own an Escalade, I just couldnt think of a name...
  5. #15
    Dec 2004
    Maryland
    half the **** is a bit of a stretch of the truth.....you helped me mount the amp and make the bracket for the lilliput. BTW roadrunner only locks up cause I still have an early version and I still didnt enable mappoint, mapmokey freedrive or iguidance.... havent decided which one to go with yet. ill put the reset switch in real soon......stupid me bought "normally closed" momentary switches at radioshack
    PC Components:
    My work log
  6. #16
    Mar 2005
    Maryland
    Quote Originally Posted by Peoples
    half the **** is a bit of a streatch of the truth.....you helped me mount the amp and make the bracket for the lilliput. BTW roadrunner only locks up cause I still have an early version and I still didnt enable mappoint, mapmokey freedrive or iguidance.... havent decided which one to go with yet. ill put the reset switch in real soon......stupid me bought "normally close" momentary switches at radioshack
    SO!!! lol
  7. #17
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Lookin good!
    alright nevermind, I did a search on the forum and found everyone says the magnets should have no effect on my LCD.
    With that said and done, I am trying to find the best way to secure it. I'm looking at cabinat catches....because remember, I want it easily removable.
    anybody have any suggestions or opinions?
    i'm looking at magnetic catches...whick might not be strong enough, and these
    Did you decide on a catch? I am actually doing pretty much the same thing, and am considering a magnetic catch or something similar. Also... how difficult did you think the 3rd din was to install? Seems not too bad, just curious about your opinion. Thanks!
    Carputer status: [-*---------]
    Im thinking laptop...
  8. #18
    Mar 2005
    NYC
    Wouldn't your 2 subwoofers affect you hdd? Vibrations and all...
  9. #19
    Dec 2004
    Maryland
    shizzle: yeah i made a mounting brack and just used 2 standard cabinat magnetic catches (hint, metal piece on the back of the lilliput is magnetic...so that cuts your work in half). I still need to post updated picks....since the bracket is all made. Me and Escalade182 made the brackout out of some wood, then I attempted to plasticoat it (didnt turn out great).....functionally it works really well....but I think Im gonna redo it with fiberglass. As for the 3rd din......it wasnt too bad....very time consuming, being that you have to take apart a lot of the interior....but all in all it wasnt that bad, the directions on handa-accessories.com's website were very helpful
    DK888: not at all so far.......in fact I havent heard of any one saying that they've had issues with this as of yet.
    PC Components:
    My work log
  10. #20
    Dec 2004
    Maryland
    heres a picture of the bracket that holds the LCD in place
    PC Components:
    My work log
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  2. p4 MOBO Recomendation
    By septicdeath in forum General Hardware Discussion
    Last Post: 01-22-2005, 05:31 PM
  3. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2004, 12:13 AM
  4. Power Consumption For P4 MB?
    By almera in forum Newbie
    Last Post: 11-27-2004, 01:47 PM
  5. MII-12000 or my spare P4 for carputer
    By Bootbox in forum General Hardware Discussion
    Last Post: 09-20-2004, 03:11 PM
