Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 81
Thread: 2005 Nissan Altima
  1. #11
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Quote Originally Posted by msb5150
    Why did you order topographic maps? Are you taking your alti off road?
    Includes all the road maps just like anything else does, but the maps look way better with the 3D views. Just personal preference I guess.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  2. #12
    FLAC edrex's Avatar
    Dec 2004
    Better Pic of USB
    Here is a better pic of the USB ports with the compartment. I'll be putting it back in the car later today.
  3. #13
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    where did you find the 28% and 15% tint?....car looks nice btw
    PC Components:
    My work log
  4. #14
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by Peoples
    Thanks. Both are Llumar tints, I just went to a local shop with a good reputation. They had samples of everything up on the walls. I would have liked to go 15% all around, but laws here prohibit any tint on the front windows and so I went with 28% because you can still kinda see through it and the police aren't as strict as if they can't see anything through the glass.
  5. #15
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Very Clean, I like it.
    TruckinMP3
    Read the FAQ!
  6. #16
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by edrex
    Today I got the USB ports attached the front dash panel in front of the gear shift. Its a 4 port hub with 2 forward and 2 rear facing. The rear ones will hide the keyboard and CD/DVD drive usb cables, the fronts will be used for the jump drive, and whatever else I need them for.
    Heard from Altimat that the headrest monitor install is coming along nicely. Will start work on the Xenarc soon, and get my amp and speakers installed also.
    Just out of curiousity, how is the hub secured to the panel? Is it simply hot-glued?
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  7. #17
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by d_sellers1
    Just out of curiousity, who is the hub secured to the panel? Is it simply hot-glued?
    I picked up some stuff from the hardware store called plastic weld, or something like that. It was in 2 tubes and you mix it in equal parts and then use it like glue.
  8. #18
    Newbie 31Charlie's Avatar
    Apr 2005
    Cali
    Sounds a lot like j.b. weld. but thats a brand name. I like how you intergrated the USB ports into your dash. Very smoth.
    31C
    The Car
    http://www.kurtvogeley.com/misc/page.jpg
    The Case
    http://kurtvogeley.com/misc/3197-4598-82307.jpe
    Not mine, but you get the idea
    [----------]0% Complete
    Give me a break Im 3000+ miles away
  9. #19
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by 31Charlie
    It was right next to the JB weld. I picked this kind because it was formulated for lots of different kinds of plastics. Worked out well.
  10. #20
    Apr 2005
    Las Vegas, NV
    I'm gonna do the same thing to my 05 altima, except i'm gonna use a laptop and put it under the passenger seat and use the cig-lighter in the center console to power it, then send the audio out to an amp in the trunk.
    My question: have you installed the screen yet? i'm trying to find a screen to fit right in the factory radio, i can't find dimensions on the Xenarc to measure, and I know the Lilliput is a little too tall.
  1. 2003 Nissan Altima Custom Liliput Dash
    By CJ8501 in forum Fabrication
    Last Post: 05-08-2008, 12:37 AM
  2. 2001 Nissan Altima screen placement
    By egeekial in forum LCD/Display
    Last Post: 06-26-2006, 01:55 AM
  3. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 10:09 AM
  4. 2005 Nissan Altima
    By mpfjr in forum Show off your project
    Last Post: 07-29-2005, 06:38 PM
  5. Nissan Altima Skin
    By CoCa in forum Media Engine
    Last Post: 02-23-2004, 08:15 PM
