Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 81
Thread: 2005 Nissan Altima
  1. #71
    Jan 2006
    New Jersey
    i dont think u mentioned anything about the audio controls on your stearing whell. just wonder wut you did with them(if anything). i'v heard of thing that let you use those controls with aftermarket headunit and such.
  2. #72
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    You can either control you aftermarket HU, with devices like the SWI line from PAC audio:
    http://www.pac-audio.com/products/pr...el%20Interface
    Or you can control your CarPC with homebrew devices + software like the one from stevieg or god of Cpu:
    StevieG's Steering Wheel Control Software
    Steering Wheel Controls
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  3. #73
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    I haven't done anything with them yet, but when I do I will be using God_of_CPU's method.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  4. #74
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    It's Edrex! Thought you'd gone AWOL.....
    In da club....
    ALIZEE WANTS YOU.....
    (\__/)
    (")_(")
    Bunny's first poo
    __ U
  5. #75
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by Spaghetti
    Just been REALLY busy lately. Keep My Thread warm for my return!
  6. #76
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    I am planning to do the exact same thing, I have an 05 nissan altima 2.5 S.
    I was thinking of mounting the xenarc the same way you have it, but was little worried about the size, now that I saw your install, that makes me more comfortable. I just need to get that metal bar you had on top, what store did you buy it from?
    -The thing i don't like is that the altima dashboard ( where you mounted your LCD screen), it is a little curvy, which makes the LCD screen come out on the edges of the frame, how you palnning to fix that?
    My solution would be to push the screen a little further at the bottom, making it look more vertical, that way the edges of the LCD will not come out. Also I thing you can see the screen better when it is vertical, is that true?
    -Where are you planning to put your dvd/cdrom drive? I am curious as to where you gonna put it?
    I was thing of getting a bezel and put it in the above compartment and and pu the dvd rom drive, the status led, hdd led and the usb ports.
    How did you power you PC, can you show me some wiring diagram?
    Also where did you cut in the ACC line?
    Thanks, looking forward to the finish projct so I can start mine.
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
  7. #77
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by edrex
    send your g/f over here and I will keep her *** warm if you like!
  8. #78
    Tainted Love Cris's Avatar
    Romania
  9. #79
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by checksum
    I got the bar from Ace Hardware. Check the section that has fence post hardware and just find things that will work.
    I have mine so that it is pretty flush at the corners. So the dash curves out mid-screen and then back in at the edges. I think it looks decent this way and visibility is fine.
    When I put it in it will be in the top storage compartment. But I have been using the PC for months and have not really needed it so its not a huge priority right now.
    Good question. I actually had a friend of mine that does car audio install for a living do all the wiring. Not sure where the ACC is pulled from, but there is 4awg wire running from the battery to a distro block in the trunk. From there, I have 8awg wire going to the amp, and smaller wire running to the power supply for the monitors and the Opus 150W that is in the computer.
    Hope this all helps.
    And Scouse: I would never let my girlfriend come within 100 meters of you!
  10. #80
    Feb 2006
    Columbia/MD
    Can you take a closer picture of the LCD mounted in the dash, so I can see what it really looks like.
    Also are you planning to fill in the little openings at the bottom ( where you cut)?
    Did you try your headrest monitors? How is the video quality? How did you connect them?
  1. 2003 Nissan Altima Custom Liliput Dash
    By CJ8501 in forum Fabrication
    Last Post: 05-08-2008, 12:37 AM
  2. 2001 Nissan Altima screen placement
    By egeekial in forum LCD/Display
    Last Post: 06-26-2006, 01:55 AM
  3. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 10:09 AM
  4. 2005 Nissan Altima
    By mpfjr in forum Show off your project
    Last Post: 07-29-2005, 06:38 PM
  5. Nissan Altima Skin
    By CoCa in forum Media Engine
    Last Post: 02-23-2004, 08:15 PM
