Results 1 to 10 of 11
Thread: '96 Renault Laguna project
    Low Bitrate 273BeLow's Avatar
    Feb 2005
    Paisley, Scotland
    So I have everything now (save for some wires and cheap stuff)
    You can see the car here www.273below.co.uk
    Car PC set up
    EPIA M10000 Mainboard (1Ghz)
    256Mb DDR266
    120Gb HDD
    Netgear 54Mb Wireless with cartop antenna
    90Watt Smart DC - DC PSU
    7" LCD Touch Screen
    GPS Mouse
    Right I've wanted to do this for near two years but only had the money recently to spare.
    I *hope* to get this done over the weekend if not then at least before the April digital car meet!
    Everything is set up software wise I just need to tear the insides of my car out and fit everything
    The TFT amazing image for such a small screen!
    The PSU a hell of a lot cheaper than the opus and does much the same.
    The amp yes it's small and cheap but I'm only driving the factory speakers till next month
    Last of all the PC itself, a mate of mine who does design ant Uni is going to make a nice perspex case which we wil ltry and get as small as I can.
    double din baby! Should be very eay to fit the TFT so far I'm just going to use some plastic blocks and velcro to hold the screen in untill I can work out how to make a unit up that looks nicer and can come out when needed still.
    The bit at the top folds down so my install will be totaly stealthed away from ned scum eyes when I'm out the car.
    Right will add stuff over the weekend as I get stuff fitted.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Welcome to another Laguna driver
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by mpattonm
    Are Clio drivers welcome too?
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    May 2003
    Czech rep.
    Especially from NL
    Feb 2005
    Paisley, Scotland
    right just a quick pictorial update, glovebox out, getting the amp power cable through the rubber seal was a night mare!
    double din unit removed for screen fitting
    the cheats way of easy speaker wiring..
    wifi antenna
    amp installed and tested
    door closed..
    door open!
    tomorrow I should get the PC housed and everything back together
    Feb 2005
    Paisley, Scotland
    meh didn't get much done today mostly wiring..
    screen fixes in the housing with velcro.. it's tough but you can get it out when you want.
    Feb 2005
    Paisley, Scotland
    ok plexi turned out to be a bad idea.. I now have had the experience of sticking a stanley knife right into my leg.. ouch.
    Bought a small B&Q tool kit which fits perfectly did a bit of an arse cutting job but I might do it with another (they are only £5 each)
    Inside, the HDD is held in place with an old VHS tape box (the tape on the top left is just till glue sets.
    back again yea cutting is ****e on the top of the panl and the firewire/usb at the top might go for it again..
    Feb 2005
    Paisley, Scotland
    done looks rather good if I say so myself
    main menu
    gps
    closed
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Very nice man!
    I can't wait to start installing mine.
    EDIT: Also, we had the same idea, I was gonna use a sterilite or tupperware container for my pc, but somebody at work told me that conduct static...
    Anybody know?
    2000 Sunfire build 100%, or is it ever really 100%?
    Feb 2005
    Paisley, Scotland
    a few updates
    first off I remounted the GPS on the outside it was losing the signal too much i nthe back window
    yes my boot is filthy how it all looks for the moment
    couple more shots of the screen and my car (going to clean and wax it this weekend)
  1. Lilliput indash in Renault Laguna '97
    By Paul_ in forum Fabrication
    Last Post: 02-26-2005, 09:01 AM
  2. Renault Laguna Puter Setup check
    By Noctris in forum Newbie
    Last Post: 05-24-2004, 06:05 AM
  3. Renault Laguna 2001 onw owners
    By mpattonm in forum General Hardware Discussion
    Last Post: 05-02-2004, 12:37 AM
  4. In-Dash 701L with a Renault Laguna?
    By Rochey in forum LCD/Display
    Last Post: 06-26-2003, 06:19 AM
