Very nicely done!! Just a thought, maybe you could paint the whole dash piece the same color, instead of the black frame around the screen. Again, just a thought. Nice idea for the bracket at the back too. Does the screen rattle or move at all now??
Hi,
what do you think of my work? Any ideas to make it better?
Thanks,
bye.
Original HiFi Car:
ITALIANI: DISPONIBILI MODULI OEM GPS:
http://www.mp3car.com/vbulletin/show...214#post639214
Current Cfg: AMD 2200+, Epox Mobo, 7" Lilliput TS, 320MB RAM, 40GB 2.5" HD, 200GB SATA, Slim Combo, ATI Radeon, SMC B/G Wireless w/ 5dB antenna, Bluetooth.
S/W: RoadRunner/MapMonkey/NetStumbler. Still working on a box and PSU!
I would love to tell you what i think although i cant really tell the outcome because the pictures are so dark
Hi,
thanks, the screen doesn't move, it is fixed whit bracket and a little of glue. This frame visible in photo don't exist now, I've removed because doesn't perfect, now I will made a frame in plastic, whit liquid plastic for a result like an original frame and some color of the rest of car.
bye
Very nice install. How do I get that panel off ? I have a megane 53
Hi ctwizard,
I've unmount the original HiFi, I've install a Radio/Tv card cinergy and connect the audio out of the motherboard to an amplifier.
The next step is to add a soundblaster usb audio card whit digital out at 24 bit and this out connect to a PhonixGold Amplifier R5.1 whit 24bit decoder for a true 5.1 sound in my car.
For the steering wheel command I will buy a irda adapter for about 50,00eur and send the infrared signal to a serial interface like Animax for command the RR interface. Vol+ Vol- Track, ecc. now working whit a normal TV remote.
Bye.
:? What is a megane 53? I don't know this model, this panel is fixed whit only 4 screw, 2 there are in the HiFi space and two are bottom the diagnostic connector.
after this screw you must make attention and pull out.
Thanks for your quick responses... What I mean was my plate is an 53 plate eg september 2003Do I need to have a external soundcard ? I have an onboard soundcard. Could I not use that ?
I've an Epia10000 motherboard whit integrated sound card, his sound suck! There isn't bass! Don't sound well. For this I've plan to add a sound blaster, usb for comodity or PCI if you have 1 avalaible. The sound blaster 24bit sound very well!
What sound card / motherboard do u have?
But your car is some to my in photo? Where are you live?
