Page 10 of 10 FirstFirst 12345678910
Results 91 to 97 of 97
Thread: 2000 BMW 328Ci (e46) - laptop install
  1. #91
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    @Drew - I am using the Audigy2NX. The sound system update (Pioneer DEH-5800 headunit, Rockford Fosgate 4004, and CDT/Elemental Designs speakers/subs) definitely made things louder and much, much better sound quality.
    The Parrot works with the Treo ok (no picture ID though), but I don't believe I'll be able to control it with the pc. PhoneControl didn't work well with the Treo at all.
    The latest project is finishing the fab needed to cover the components in the trunk, and diagnosing the headunit's crappy radio reception using the stock antenna wire. The reception problem may have to do with the headunit's proximity to the rest of the equipment in the trunk. I did get the girder/UIRT control of the headunit to work perfectly.
  2. #92
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Quote Originally Posted by Hark
    @Drew - I am using the Audigy2NX. The sound system update (Pioneer DEH-5800 headunit, Rockford Fosgate 4004, and CDT/Elemental Designs speakers/subs) definitely made things lounder and much, much better sound quality.
    Do you have problems resuming from standby/hibernation?
    Rich
  3. #93
    Feb 2005
    Atlanta, GA USA
    No - the only thing is that XM doesn't come back properly when resuming from s/h in RoadRunner - have to switch to menu/mp3 and then go back to XM for it to work. I think this is because my XM unit is connected via USB, and the hub is unpowered, so there is a delay in the XM unit coming up when the PC's operation is restored. I'm going to try and wire the USB hub to the acc line and see if that helps. The girder/UIRT solution seems to work fine after standby/hibernate, and I've got the "amp control" service running to power on the hu through a USB port line as well, to eliminate the amp pop.
  4. #94
    Feb 2005
    Atlanta, GA USA
    Screen died a little while ago (POS). I'm going to take it all out, sell it, and replace it with an Alpine IVA-W200. I'll post something in the classified section soon for everything - in the mean time, if you want anything I've listed here, let me know.
  5. #95
    Oct 2004
    St. Louis area
    wow...that really sucks! what happened to the screen?
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  6. #96
    Feb 2005
    Atlanta, GA USA
    Not sure, but I do know that the brightness had gone downhill, and I think I'm tired of messing with this stuff in general - want something more reliable, less maintenance.
  7. #97
    Feb 2005
    Atlanta, GA USA
    Here's the link to the thread where I'm selling all of this:
    http://www.mp3car.com/vbulletin/show...379#post828379
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  2. FS: BMW E46 Carputer trim for ashtray area.
    By srcstc in forum Classified Archive
    Last Post: 06-06-2005, 08:23 AM
  3. Laptop Install Help!!!
    By Inspiron8500 in forum General Hardware Discussion
    Last Post: 07-02-2004, 11:21 AM
  4. Laptop Drive install questions (pics)
    By bosstone74 in forum General Hardware Discussion
    Last Post: 02-21-2004, 02:42 AM
  5. NewB Questions for Laptop Install
    By PaulDePimp in forum Newbie
    Last Post: 02-09-2004, 11:57 PM
