Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 97
Thread: 2000 BMW 328Ci (e46) - laptop install
  1. #31
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Here's how I ran the wires from trunk to dash:
    With the back seats folded down, you can see the hole where the wires run:
    Then, with the back seat out, you can lift up on the shoulder padding part and pull the cable through:
    From there you can run the cables where the others run in the door jam:
    Then I took out the front driver's seat (tip: the tire iron in your car's toolkit is the right size to loosen/tighten the nuts holding the seat in place), and ran the cables underneath it (following the crease already in the carpeting), and ran the cables into the center console/armrest, underneath the gear shift, and up to the dash where the monitor sits.
    The hardest part was getting the plastic cover off of the door jam that exposes the end of the carpet so you can pull it back and run the cables. You really have to pull up hard on it, and I had to replace some of the white clips that hold it on, but they're really inexpensive.
  2. #32
    Feb 2005
    Atlanta, GA USA
    Here's a pic of a cooling fan that I installed over that vent in the trunk area, which as it happens also shows the red ignition wire coming from the mess of cables, which I'm sure I just spliced from one of the CD changer cables:
  3. #33
    Feb 2005
    Atlanta, GA USA
    Here's how I mounted the laptop/amp:
    On the other (bottom) side of the board, I put the weeny stock amp:
    Here's how it looks when it's put into place. I've since replaced the metal hinges at the top holding it in place with zip ties (makes it much easier to undo when I need to rewire things):
  4. #34
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Quote Originally Posted by Hark
    The easiest way to remove that is to pull out the last 2 white clips (one is sideways and the other is angled) then you can actually slide the sill cover back leaving all the other clips still attached to the body. Then you just pull out each clip with needle nose pliers.
    Nice work btw.
    Rich
  5. #35
    Jul 2005
    NJ
    hark its looking good. i have a question though. Did you use an aux adaptor where the cd changer was. I just recieved my USA SPEC interface adaptor with 2 rca inputs...so i turn my car off. I locate the cd changer cords. There wrapped up in a piece of felt. I plug the 3 pin and 6 pin into the adaptor...rca's into my laptop....turn on my car and i hit cd. it shows 6-1 and 6-2. 6-1 is the first aux input. Play some music and hear nothing. try 6-2 and plug in there...nothing happens. the Only thing i hear is when i full blast the volume a small faint noise. i call up crutchfield..guy basically doesnt know what a BMW is lol...so there sending another out monday. Did i do anything wrong here?...what the poopsicles is goin on. any suggestions?
  6. #36
    Feb 2005
    Atlanta, GA USA
    Sorry, can't help you - I removed my CD changer since all my music is on the laptop. I can tell you that the 3-pin connector for the CD changer is the IBUS, I assume the other plug is the audio-out.
  7. #37
    Jul 2005
    NJ
    hey hark have you traced the acc line. just wonderin where to tap into with my shutdown controller..let me know when you have a chance
    thanks
  8. #38
    Jul 2005
    Hark, can you clarify where you placed the BMW harness? From your Visio diagram it's shown right by the HK amplifier; curious if you have found a way to hook it up to amp right there, instead of running separate 4ch audio cables all the way to the front. My constraint is, just like many others, to not make any permanent change to original wiring. I don't want to cut anything.
    It would really help if you can list the wires that goes from back to front.
    Thanks.
  9. #39
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Magician:
    If you don't want to cut anything you will have a hell of a time connecting up to the amp in the trunk. The connector is a monster (40-something pin) connector and even after you untape it all you'd still have to trace the wires and use vampire taps. You can do it that way if you really have to, but I guarantee that it's faster and easier to run some cables up to the front. The other thing to consider if you tap in at the amp is that you have 8 very long unshielded wires essentially dangling off of your audio cable. While the audio is balanced and should eliminate most of the noise that this kind of problem would cause, it certainly is not optimal.
    Jir1984:
    AFAIK, nowhere except actually behind the key in a BMW is there an official "ACC" line that is on and 12V when the car is on. All of the other 12V lines that go high when you turn the key are seperately fused and controlled by the ECU in some way. In this regard, I would recommend that you use the 12v ignition wire in the wiring harness for the radio/headunit to control your shutdown controller, running an extension back to the trunk if that is where you have located your computer. That being said, this line will actually *be* in the trunk if your car has NAV. Even if the car does not have NAV there are a couple of other points where you can get a 12V when the car is on out of the trunk. Both the alarm harness on the right side of the car and the telephone module harness on the left side of the trunk will have a 12V acc-type line. Please be cautious using these as I can't guarantee that they are always on when the car is on and always off when the car is off. I also have no idea how they are fused or if it would be a good idea to run a shutdown controller off of them.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  10. #40
    Jul 2005
    Gork, thanks a lot for the prompt response. I'm convinced to run the cables to the front. Here is my list of cables; I'd appreciate if you can comment.. (FWIW, I have 2000 E46 4 door; laptop goes to trunk, xenarc 700ts goes to upper bay; for now, there is nothing else in the front, keeping HK amp, removing the head unit)
    - 4 x thin coaxial audio cables (these are very similar to RG6 from specs standpoint, but about 2mm in diameter -- I had some 20 meters of it and because it's thin, I'm thinking it'll help)
    - 1 x RG6 for extending antenna back into the trunk where I'll connect some USB FM receiver.
    - 2 x 18-2AWG flex cables for various power needs (total of 4 wires; 2 will supply xenarc, other 2 is spare (may be a small USB hub later) ). Xenarc's own DC supply used 20AWG, I couldn't find 20 so next best thing is 18 -- hope this is appropriate for power.
    - 1 x VGA extension cable. This connects to xenarc's VGA cable somewhere around handbrake.
    - 2 x Cat6. Now these are spare but I figured, each has 8 wires, running these will give me enough flexibility to do other things. I have no intention to do wired ethernet in the car. Things like OBD, radar detector etc comes to find (for future).
    - 2 x USB extension cables. One of these drive the touch screen on xenarc, other is for future use.
    - (Thinking of using 1 wire inside one of the Cat6s to connect shutdown controller to AMP enable)
    - (Also was thinking of asking whether the black wire on SVEN4 was supposed to go the front -- again hoping that Cat6 reserves can be used for this purpose)
    So what do you think?
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  2. FS: BMW E46 Carputer trim for ashtray area.
    By srcstc in forum Classified Archive
    Last Post: 06-06-2005, 08:23 AM
  3. Laptop Install Help!!!
    By Inspiron8500 in forum General Hardware Discussion
    Last Post: 07-02-2004, 11:21 AM
  4. Laptop Drive install questions (pics)
    By bosstone74 in forum General Hardware Discussion
    Last Post: 02-21-2004, 02:42 AM
  5. NewB Questions for Laptop Install
    By PaulDePimp in forum Newbie
    Last Post: 02-09-2004, 11:57 PM
