more pics
just some different angles
so yeah a lot left to do but got a lot done... hopefully tommorow ill get some bondo on this piece...
pictures!
This is where the LED for security system was I will be bondoing this too Haven't decided where to put LED yet... Suggestions?
more pics
so i pulled an all nighter... got the bondo on there... need more sanding supplies... and probably a decent file. the piece will most likely need more bondo! and more sanding I'm going to say with everything that needs to get sanded down and repainted maybe like 20 hours!! but yeah happy to be closer...
pics of bondo next week
nebody? comments? at least looks good so far.. or if it looks like *** tell me.
grrr
the pictures above look like ***, but im sure the bondo will fix that.
Lol thanx for the reply! this Epoxy has all been sanded down and bondo-glass is applied just don't have pics up yet... maybe next weekend i will, and everything will be done as well.
Hey, I have a 93 civic sedan as well, but a dx. Its good though, since I pretty much made it an lx-SiR...![]()
Where are you going to mount the HU??
Have you seen the optional audio console? Alot of people think its a JDM piece, and it is, but one was made USDM as well. Im using that to mount the screen, but it removes the cupholders. There is a single din cupholder that slides out that I want to use, but then there is a lack of space on the puny dash that honda so generously gave us. Ive even thought about knocking out the 2 center vents and making a custom HU mount there, so there is plently of space in front of the shifter.
I will not be running a H/U All sound will come directly from the computer and goto 2 amps located in the trunk... I will post pics of the PC as I start the Glassing process of all that (PC, Subs, Amp) but i'm running the SB audigy live for audio still need to buy 2nd amp
So far so good man... It's coming along pretty nicely. Just seeing that dashboard brings back some memories... I used to own a 92' sedan myself. Fun cars when u learn how to appreciate them. Keep it up!
hey anky, i need you to do my dash next, k?
1995 Saturn SC2
