Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: It's alive...stage 1 Galant PC
  1. #11
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Talking Stage 2 (Trunk)
    I was working on my, over the week...it's not done...At the pawn shop I picked up (1) 4ch JBL & (1) 2ch Sony..both for 120.00
    This week I plan on finishing the trunk: running 4g wire(power), 8g(ground), fuse and grounding block. Not pictured are the sub box enclosure. Let me know what you think...
  2. #12
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    What kinda heat dissipation are you gonna put on those amps? I notice you pulled the heatsinks off the JBL.. Those Sony's are prone to overheating as it is...
  3. #13
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    pretty nice so far, is that a pioneer dsp unit in the trunk? if so, how do you like it?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #14
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I second that.....
  5. #15
    Feb 2005
    Miami, Florida. 305
    Not pictured are fans that I have..if you notice the back is open, I may add the heat sink on the JBL...
    Not dsp..it's an xm receiver...
  6. #16
    Feb 2005
    Miami, Florida. 305
    Screen molded in and primed...Depending on the weekend (rain) I should begin to install everthing...
  7. #17
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    You are gonna have to install some kind of cooling onto those MOSFETs or you are going to toast both those amps. I see you want to display the circuit boards of the amps, which is cool, but you absolutely have to use some cooling... whether it's a heatsink, or some kind of water cooling setup. I did see an install in a magazine where the owner ran a water-cooled setup using 1" square aluminum tubing with the MOSFETs connected to it. The water coolant ran through the aluminum tubing, then into clear plastic tubing, through the cooling system's radiator/fan them pump, then resevior, then back through again.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  8. #18
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    Without heatsinks or the suggestion made by Snootch, you'll probably set fire to your car never mind toast the amps...
    Don't mean to rain on your parade mate, but I just want you to be safe!!
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
  9. #19
    Feb 2005
    Miami, Florida. 305
    After reading post about my amp (heat sink), I guess I'll put 'em back in there case. I do have fans blowing air in and I thought that would go...
    Now, I have to reconsider my trunk lay out...Thanks for the input.
  10. #20
    Springfield VA
    looks good so far!!! how about some more pictures of that case?
  1. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 02:04 PM
  2. OPUS 150W Behaviour on PC error
    By Jamez_Warner in forum Power Supplies
    Last Post: 05-09-2004, 02:31 PM
  3. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 03:02 PM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 01:42 PM
