Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 70
Thread: '05 Corolla S computer install, lot of pictures [in progress]
  1. #51
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    The M1-Atx is really nice really small small component and it replaces both ATX PSU and Inverter, and much more efficient. The only thing is it's 90W but right now it's more than enough to power my M10000, a usb mouse, my touch screen monitor, a rear camera, a 3.5" old hard drive..
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
  2. #52
    Jul 2005
    /lurkmode = 0
    Hey dude,
    Great job so far.
    I have a question about your 'glassing. I am halfway through a similar project (got halted for winter, then I went to Europe for a few months... still there). I followed the same preps. Total mask with tape, then tin foil on top. I have done about 4 coats.
    However, when I tried to remove it, it seemed quite well attached. I would start breaking off pieces off of the edge of the glass rather than lifting the shell off. I made absolutely sure everything was masked, so I know it's not bonded to the metal (using spare tire well). I think it is just because the masking tape sticks much better to metal than to carpet. I plan on heating the spare tire well from below to loosen the tape.
    Was your shell tough to remove? Any tricks?
    Thanks man. Keep up the good work.
  3. #53
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    I'm looking forward to seeing the sub box and pics - that should be cool!
    So far, looks good. I got a bit of fiberglassing ahead of me this weekend, too.
    - Jeff
    95 Mustang GT Convertible
    87 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
  4. #54
    Feb 2005
    Hi again all !
    I'm on the way to finish it ... but I need more time !!
    I'm doing the MDF rings right now, I'll need another couple of fiberglass layers and I'm gonna be lal done for the sub box. I'll cover it with black carper (see computer case) later.
    For your question stoanhart, if was really easy to remove because of the aluminum foil.
    My Corolla Computer
  5. #55
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Cool, nice job with the pc mounting
    I have an Australian 2002 Corolla, which looks similar to yours. I've mounted my car computer in the same place that you're mounting your sub with an oblique shaped MDF sheet, and i made a new boot tray so i could screw it into that.
    Nice to see more Corolla car computers.. Next thing i have to worry about is how to mount an LCD in mine.
  6. #56
    Newbie Gerardc6's Avatar
    Oct 2005
    Los Angeles, CA
    Aux Input
    Quote Originally Posted by CapitaineFritz
    I didn't found anything similar on the net yet.. but I saw a few installs with one (and it was hand made )
    I just started the University today so I'll have less time.. (and money!) to continue, but as soon as I have new pics I'll post them
    P.S.: I would REALLY like to have an aux input but can't find any information on what kind of radio do I need ? Do I need the stock WITH cd-change controls ? Do you have the cd-changer controls on yours ? How do you switch audio source ? If you don't need yours anymore, I'm really interested !
    Hi Fritz,
    There are many head units with Aux inputs in the $100USD range. In fact, I've seen a couple at our local electronics store. That's happens to be my price range as well for a head unit. One thing I notice though, is they all only take in Stereo inputs.
    So our CarPCs can put out 6 channels, but if the signal goes to the head unit via aux input, you're limited two channels. I think that's the reason people choose to intercept the Head Unit's signal and use it as input for the Car PC's sound card.
    Gerard
    AMD X2 4200+ Media Center 2005 with TV+FM
    1 GB DDR, 250 GB SATA, DVD Burner with LightScribe
    Xenarc 1020tsv
    Kicker S12L7, KS65.2, KS693
  7. #57
    Oct 2005
    Los Angeles, CA
    Lightbulb Anti-Theft
    I'm just afraid of being stolen... so I want to keep everything stock. That's why I plan to put the screen behind the two small doors.
    I just had an idea for theft-deterrance. Put a thin cloth that's custom cut to surround the whole dashboard and the center console area. The ugglier the better. Actually, I picture a black knitted cover, sort of looking like a granny car. But the thin cloth is probably quicker to roll up and stowe under the seats. I'm concerned with theft as well.
    Gerard
    Xenarc 1020tsv
  8. #58
    Oct 2003
    Grants Pass, OR
    Looks nice. Your vehicle layout is really similar to mine, might be... erm... "borrowing" your idea for the PC mounting. Especially after a recent incident involving a week of rain, a trunk leak, and 2 inches of highly conductive water sitting in my spare tire well.
    Ah, nothing like a forced hardware upgrade signalled by the Magic Blue Smoke.
    2003 Toyota Camry V6
    Kenwood Excelon 790 HU, VIA C7 + M2-ATX, Xenarc 700TSV, and 5 discreetly installed amps.
  9. #59
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    How many screws are you using to mount the wood to the chassis of the car?
    Cos I can see only 2 which would mean the computer would swing each time you turn etc.....
    [edit] Just realised by screwing the folding bit with the hard drive right up to the chassis this prevents it from swinging from side to side.
    Fox Mulder
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
  10. #60
    Dec 2005
    CapitaineFritz,
    I really like your bug guard what is the name of the manufacture and model number.
    Klua
