Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 121 to 130 of 148
Thread: Bugbyte's 2001 New Beetle -Mac Mini Install
  1. #121
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I use a Rotozip saw to cut the plexi. You don't need a Rotozip, though. A Dremel with a Rotozip bit in it (sometimes called a spiral cutting bit) will do.
    To cut the cupholder, it just happened that a 2" hole saw worked. I used a drill press to do it. It got tricky at the end, the saw wanted to grab the piece and I had to wait a couple of times to let it cool down. Then, some sandpaper.
    Want to:
  2. #122
    Apr 2005
    monroe/louisiana
    help please
    First off,
    Thanks for your wonderful worklog.
    i've been trying to make a dock and have reached a problem. i used a drimill to cut the holes and vent but when i went to cut the piece from the sheet of plexy, using a jigsaw , the heat from the saw would melt the piece back together as i was cutting. i finally got the right side to seperate by pressing down on the piece while sawing, causeing a serperation but as you can see that didn't work to well.
    Any suggestions?
    Also, what are the outer dimminsions that you used, meaing from edge to edge on each piece?
  3. #123
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    To cut the basic pieces I used either a radial arm saw or a bandsaw. The radial arm saw cuts super straight with no melting.
    If you don't have access to either of those tools, a jig saw will work. However, it would be best if you had an adjustable speed jig saw. I set mine to the lowest speed and use a fairly coarse blade. It takes some time to make the cut but you'll know if you are going at the right speed when you aren't getting any melting.
    For the outer dimensions, I measured the width of the Mini and added 1/2" for the two 1/4" plexi pieces. I cut it just a bit wider than that (maybe 1/8" or a little more). Before gluing anything, I embedded all of the connectors in the back wall of the dock. I put the back plastic sheet over the Mini, plugged all of the connectors THROUGH the plastic and into the Mini so I was absolutely certain they would be in the right places. Then I used epoxy to glue the cables in place.
    After that, I covered the Mini in plastic wrap and, with the back of the dock still in place, glued the side pieces in place, clamped tightly against the sides of the Mini. I later sanded everything flush.
    BTW, I also included a piece across the top and bottom of the Mini and sanded them at a shallow angle so when it goes into the dock, it is guided precisely into place. It's worked so far.
    Want to:
  4. #124
    Jun 2005
    Seattle
    still very impressive. Bug, have you done this in any other material (just to see how it works/what it looks like?
  5. #125
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No. It works fine with plexiglass. No need to redo it, although I guess it would work fine using ABS or fiberglass sheet. I don't see why wood couldn't work, either.
    I wouldn't do it in metal, because it's a more difficult build. If you had access to a CNC flowjet, an 1/8" aluminum would be excellent. Otherwise, I wouldn't try to cut it by hand.
    Maybe a set of 3d plans and a build from e-machine shop or a stereo lithography output would work but it would be expensive.
    For me, the bulk of the work wasn't the dock. I mean, that took some time, but it was pretty straightforward. The time and effort was in the hacking and integrating the dock into the ductwork and dash itself.
    Want to:
  6. #126
    Newbie tjsharktank's Avatar
    Jul 2006
    Charleston
    Thumbs up
    I love your install. It looks really clean. I especially love the plexy. Thanks for posting all the pics too, it really helps people like me
  7. #127
    Oct 2006
    Windows on the Mac mini? Front end? GPS?
    I'm very impressed with your install. It looks awesome. I'm curious about your GPS endevours though. I want to install a mac mini in my car (02 WRX) - but GPS is the primary reason for the carputer - so it needs to work well. I had an idea - now that mac's run Windows:
    Set up the mini so it boots Windows first. My only concern with doing this would be a slower time till the system was up and running - and that 3-5 seconds when waking up the mini is too good to lose. Has anyone tried to use the macmini with Windows? How long does it take to wake up from sleep mode? Also, would it then work with PC based front ends and "better" GPS software?
    Sorry if these questions aren't entirely relevant to your thread. Just figured this would be a good place to get the ball rolling.
  8. #128
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Check in the Mac car forum. You can run Windows on the Mini. You can run Windows front ends on the Mini. You can run a product called Parallels that allows you to run Windows AND OSX at the same time and switch between them. This preserves that quick wake up time.
    Want to:
  9. #129
    Oct 2006
    awesome, thanks so much. I'll keep you posted as to how my system pans out. Still trying to spec it out and see just how much $$ I'm gonna have to lay down. Thanks again.
  10. #130
    Nov 2006
    El Paso, TX
    Your post gave me an idea and I did some research:
    Mac Mini is the BEST Price vs. Performance compact platform you can get (try pricing a core 2 duo Mini-ITX system). It has almost all the bells and whistles one would ever need for a little more than half the price of a custom system.
    My point is, ditch the OS X. Get WinXP with a proper frontend and you'll be in business.
    P.S. This is IMHO, not a flame. Love your work.
  1. MKIV Supra TT - Mac Mini / Custom Dash / Custom Boot
    By tresseh in forum Show off your project
    Last Post: 01-18-2012, 04:35 PM
  2. Mac Mini MINI
    By FireAnt in forum MacCar
    Last Post: 07-30-2008, 06:06 PM
  3. Mac mini mobile
    By haharich in forum MacCar
    Last Post: 05-16-2005, 10:38 PM
  4. Hybrid Mac Mini Giveaway!!
    By Bitoholic in forum MacCar
    Last Post: 03-10-2005, 09:06 PM
  5. Replies: 33
    Last Post: 01-20-2005, 10:52 PM
