Thanks, Mike. I looked at them and they appear to be virtually the same size as the slimline connector. Perhaps a bit smaller. I'm also worried a little about stacking a connector on a connector to a cable to a... you get the picture.
I intend to cut the strain relief on the slimline connector and right angle the cable. That's what I had to do with the Xenarc connector on the screen install and if you're careful, it works.
I suppose the proper way would be to get a DVI-VGA cable and cut the strain relief that way. But they're $$$ and no matter what, the fact that the cables project even an inch out of the back of the mini means I have to cut into the heater box behind it. Once you do that, you get an extra couple of inches of space.
If it looks REALLY tight back there, I can always go to the right angle connector.
LinkBack URL
About LinkBacks
