Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 41 to 50 of 148
Thread: Bugbyte's 2001 New Beetle -Mac Mini Install
  1. #41
    May 2005
    Quote Originally Posted by Bugbyte
    I've used Great Stuff before, around the house, but it dries to be sort of hard. Do they make a version that stays flexible?
    The window and door jamb great stuff dries much softer. Its made not to expand the jambs as much and allow for movement.
  2. #42
    May 2005
    If you feel like driving to College Park, MD during the day or Upper Marlboro, MD during the afternoon I can give you some 1/8 or 1/4 inch one sided foam tape. Have tons of the stuff.
  3. #43
    Jun 2005
    have you thought about some dynaliner? www.dynamat.com
    you could just apply it to the exterior of your plexi box, the thickness should fill all your gaps and it's heat resistant to about 225F
  4. #44
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    One step closer...
    I implemented the solution to the power wire problem that I sketched out a couple of posts ago.
    I took two ballpoint pen springs and soldered wires to them. I drilled holes in the dock and embedded the springs in the dock. Then, I took two brass grommets that are used to mount radio controlled airplace servos and filled them with solder and a wire. I drilled a hole in the back of the Mini where the springs touch and then glued them in place on the Mini.
    I soldered the power wire pigtail to the wires coming out of the grommets and was finished. I then docked the Mini and tested it for continuity with my voltmeter on both wires. It worked great!
    I gotta say, I thought this was an inspired solution. Especially since I completely boneheadedly overlooked the problem to begin with. Here's some pics:
    Here's the dock with the ballpoint pen springs mounted in it.
    Oh yeah, I almost forgot. I drilled through the bottom of the plexiglas heat shield I built and tapped screws through it and ever so slightly into the bottom of each plug in the dock. That should keep them from coming out!
    Want to:
  5. #45
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    I read your post on another thread...now I'm curious. Where you at? Looks pretty sweet so far!!
  6. #46
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Haven't been able to work on it for the last two weekends! Out of town both weeks. As you can see, I'm nearing the actual install of the dock and that's why I'm thinking about my options for the audio output.
    I'll have a chance to work on it a bit this weekend. I've got to fiddle with how to make sure the heater ductwork doesn't blow into the Mini enclosure, so that's what I'll concentrate on this Saturday or Sunday.
    Once that's complete, I'll be taking the covers off the top of the dash to see if there's enough room to bury the P1900 PSU and perhaps the headunit/amp or whatever I figure out to do.
    Final assembly is still about 3 weeks away, if I can work on it at least one solid day per weekend. I usually understimate, so 6 weeks is probably a better guess! I'm getting really antsy about having the box just sitting in my basement without doing anything so that's motivating me.
    Want to:
  7. #47
    Jun 2005
    Seattle
    right where you have the binary code on your sunroof avatar, you should install a solar panel (inside of course) between the glass and fabric cover in the car. A perect solution to recharging or day time seperate power source.
    Someone makes 2 side by side 8 1/2 x 11 panels to power laptops. That would fit perfect.
  8. #48
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Quote Originally Posted by thecolor
    I think VWs and Audis come from the factory with little solar power panels that attach to the window with suction cups and plug into the cig. lighter. The dealer removes them when they get the car. If you know someone at a dealership, you could probably get one. I'm not sure what the output is but I am sure it wouldn't power the PC but it would charge the battery during parking time.
    - Jeff
    95 Mustang GT Convertible
    87 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
  9. #49
    Jun 2005
    Seattle
    I've seen that at a few dealerships. But the suction cups look so tacky. Like baby screens stuck to the window. A nice clean look seems so much better, dosn't it?
  10. #50
    Mar 2002
    Yeah, it probably wouldn't look the best...How would you mount the other panels?
    - Jeff
  1. MKIV Supra TT - Mac Mini / Custom Dash / Custom Boot
    By tresseh in forum Show off your project
    Last Post: 01-18-2012, 05:35 PM
  2. Mac Mini MINI
    By FireAnt in forum MacCar
    Last Post: 07-30-2008, 07:06 PM
  3. Mac mini mobile
    By haharich in forum MacCar
    Last Post: 05-16-2005, 11:38 PM
  4. Hybrid Mac Mini Giveaway!!
    By Bitoholic in forum MacCar
    Last Post: 03-10-2005, 10:06 PM
  5. Replies: 33
    Last Post: 01-20-2005, 11:52 PM
