You could use a clear adhesive so they give as much clearance to the automatic slide mech as possible. (allowing a slide under the roof as initally designed). You would not want to use to much though as photocells use pretty much the entire surface. If you block one cell from light, it typically effects the others (depnding of course on manufacturing).
