Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 73
Thread: 1994 Oldsmobile Cutlass Supreme SL - not done yet, but close
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    So... how do you control the screen? With your foot?
  2. #12
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    No - I have to use a mouse - I could use my foot tho,
    I used to play that game on the nintendo that had a robot with
    it - but I got mine at a flea market with out the robot - so I used
    the first controler with my hands and the second with my feet
    I played 2 player games like that to - sad just sad
    I had got the screen in hopes that the touch screen worked
    but it was fried - on top of that the inverter and ccfl were
    going bad - I am glad I only paid $50 - I went to elwirecheap.com
    and got a Cold Cathode and Inverter - it was about $10 plus shipping
    worked perfect
  3. #13
    Variable Bitrate Bodgy's Avatar
    Nov 2003
    Briz Vegas, Australia
    hey will.... u a member of diy audio?
    nice install there mate, looks like you can keep up with multiple projects better than i can!
  4. #14
    Feb 2005
    Jefferson, AR U.S.A
    yep
    If you only knew - I am so absent minded it sad - I cooked
    food 2 times today - both times I forgot and burnt it
    I got ADD real bad
    I have been working on my car, and some on 2 video
    projectors - on top of that I have been planing to build
    a work shed and thinking about a making a new dune/mud buggy
    Here is a another pic
    Here you can see the slim line cd drive - and the arm rest were I hide
    my joystick and USB hub
  5. #15
    Feb 2005
    Jefferson, AR U.S.A
    Here is my Joy stick, mouse and keyboard\
  6. #16
    Feb 2005
    Jefferson, AR U.S.A
    I am trying to keep the Image size down - I feel guilty about the
    bandwidth usage
    here is the arm rest open - its perfect for hiding the mouse and stuff
    you can see the USB hub also
  7. #17
    Feb 2005
    Jefferson, AR U.S.A
    Here is how its wired to power - XP does not need a shutdown controler,
    - just disable "Write Caching" on the hard disk and cut power to the
    computer - no need to shutdown at all
    Also my LCD is powered from 12v out of my computer
    I have a push button in my cup holder that turns the computer
    on and off - that way I can have the radio on without the computer
    When I get the M1-ATX - I will have to re-wire
  8. #18
    Feb 2005
    Jefferson, AR U.S.A
    The Cost
    Computer -----------------------------$50
    GPS-----------------------------------$90*
    Hard Drive-----------------------------$30*
    Memory-------------------------------$30*
    FM Modulator--------------------------$15
    Power Inverter-------------------------$35
    Mouse---------------------------------$10
    Joystick-------------------------------$10
    DataLux LCD---------------------------$50
    Slim Line CD-Rom Case -----------------$15
    CD-Rom for Slim Line Case--------------$20*
    ATI TV Wonder usb 1.0 ----------------$15
    4 pin relay ----------------------------$5
    MINIKey miniature keyboard ------------$15
    Usb 2.0 PCI card ----------------------$10
    CCFL and Inverter to fix the datalux ----$15
    4 port usb hub ------------------------$5*
    IDE cd burner 24x ---------------------$20*
    Spent so far --------------------------$440
    * some of this I had laying around
    And if you count the subs, head unit, box, amp
    thats another $400
  9. #19
    Low Bitrate madmartigan's Avatar
    May 2005
    Canada
    You should go wireless with all your input devices.
  10. #20
    May 2004
    Rockin the cutlass!
    lol i got the same car and toolbox in my trunk, same job too
    i drop you a message when i get my 92 cutlass complete.
    Good job
