Last weekend I was on a small road trip and had some friends in the car,
computer was working, and I shut the car down like normal, went into a
store for about 20 min and came out, the car would not start, at first I
thought dead battery, but the gauges said it was fully charged, and I could
hear the relays clicking under the hood, but the starter would not engage
I tried a few more times but nothing, I popped open the hood, and I
decided to remove the fuse going to the computer and amp that's in my
trunk, and then tried to start the car, it worked perfect
Later on at home, I hooked up the fuse and the computer would not
come on, but the car did start, and my amp worked, no fuses were blown
I even tried the M4-ATX reset a few times, I then thought maybe my
motherboard was dead but I tried it in the house with a regular ATX
power supply and it works fine
So it looks like my M4-ATX
has died
I am back to using an inverter
I see nothing burnt on the M4-ATX, and the fuse on it is still good
I am going to send it into mini-box to see if I can get it fixed
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
