Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 112
Thread: 2000 Pontiac Trans Am carputer install
  1. #21
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Thanks!
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  2. #22
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    wow, i just noticed your webpage. you have one bad *** system in there already, nice work
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #23
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    hey, where did you get the carpet for your install? is that what people normally use? I really like the new amp rack.
    PC Components:
    My work log
  4. #24
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by Peoples
    I bought the carpet at a local auto upholstery shop. I tried to find the closest matching un-backed carpet I could find.
    WORKLOG
    Webpage
  5. #25
    Low Bitrate c4shm0ney's Avatar
    Jul 2004
    Indianapolis
    Nice install, looks good.
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
    http://www.mp3car.com/vbulletin/worklogs/51295-01-metro-lsi-4-door.html
  6. #26
    Sep 2003
    Tampa, Florida
    I mounted some ABS sheets on the right side of the cavity of the dash, and mounted my 250Gb drive to it. Then, I mounted the SP-13000 and M1-ATX to another sheet along the back. The ABS sheets are held in place by screws, aluminum brackets and velcro. Pic:
    WORKLOG
    Webpage
  7. #27
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    That is looking awesome! I wish I had that kid of room behind my dash...and a bezel....
    - Jeff
    95 Mustang GT Convertible
    87 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
  8. #28
    Sep 2003
    Tampa, Florida
    Painted the bezels, First I cleaned them with acetone, and sprayed the parts with Duplicolor Adhesion Promoter. Then I coated them with SEM texture spray to give them a pebble-grained texture:
    Then, I sprayed them with the adhesion promoter again, then two coats of Duplicolor Bumper Coating (Black). In between the coats I flattened the pebble grain a slight bit by rubbing the surface with some steel wool:
    It is all ready to go toghether, but I have a few things standing in my way:
    1. My in-laws are here, so I can't spend any time working on it.
    2. When I tried to power it up earlier, I got no display on the screen. The board powers up, as does the HDD, and I get a "VGAMODE" and NO VGA SIGNAL DETECTED" display on the screen (so I know the screen is powered) But no BIOS splash screen, or no windows display. I also checked power with my meter, and the power supply is supplying +12 and +5v. The next step I'm going to attempt is to hook up my desktop CRT to it to see if I get a display that way.
    WORKLOG
    Webpage
  9. #29
    Mar 2002
    That's looking great. I'm anxious to see it in the car!
    - Jeff
  10. #30
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    looking good!
    but one problem, in post 26, did you leave the pink foam that the mobo came packed in on the back of the board? Because if you did that foam is conductive and will give you many headaches
    肚子笑痛了
    S60 Install
  1. pontiac sunfire 2000
    By Phantm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 10:00 PM
  2. 2000 Sunfire Install
    By CavityCr33p in forum Worklogs
    Last Post: 04-13-2005, 12:33 PM
  3. 97 Acura Cl carputer install
    By elserpiente in forum Show off your project
    Last Post: 04-11-2005, 05:48 PM
  4. Replies: 1
    Last Post: 02-03-2004, 02:02 AM
  5. Ready to install Carputer
    By petera in forum Power Supplies
    Last Post: 01-05-2004, 12:52 PM
