Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 112
Thread: 2000 Pontiac Trans Am carputer install
  1. #61
    Jul 2005
    Calgary
    snootch that is one *****in ride. between seeing your trans am (reminds me of my 77 T/A - FUN DAYS) I heard the f-bodies aren't made anymore tho.. good thing there still the Mustang GTs...
    ps - too bad about that foam packing oops but you've made up for it with a professional level install.
    edit: cleaning up posts
    99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
    97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
    currently: installing (finally!)
  2. #62
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Great job!! I have been wanting a trans am since I borrowed my uncles 2000 for a few weeks while he was out of town. Great cars and you have an awesome install!
  3. #63
    Registered User 1stbird's Avatar
    Sep 2005
    Hey Snootch,
    Love the install! I've got a "new" 2001 Formula and just love the idea of a carputer! What kind of software are you using?
    I got CarShell from Alti (you are my [computer] god now! What an awsome piece of software! No carputer yet, but I have tried it out on my desktop!) I've read about Road Runner, but where do you get it from? Is this a shell like CarShell or is this for navigation (GPS)?
    Still would like to know what software you are using. It looks AWSOME! BTW, have you guys ever heard about "Realise Voice"? It lets you speak commands into your computer, rather than using your mouse or keyboard! Wouldn't it a powertrip to be able to "tell" your computer to "Open WinAmp" (or whatever) rather than having to push a button?!? My mind is racing with all of the possibilities! K.I.T.T. car, here we come!
    1stbird
    2001 Firebird Formula
    Purchased 8/19/2005
    LS1
    6 Speed (M6)
    Ram Air Hood (Dealer Installed)
    Ram Air Box (Dealer Installed)
    K&N Air Filter
    CAGS Eliminator
    DRL Disable
    Black on Black
    No T-Tops
    GM Factory Bra
    Pilot Motorsports Shiftknob
    Pilot Motorsports Pedal Covers
    "My old lady left me and took my Firebird the other day. Damn, I miss that car!"
  4. #64
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by 1stbird
    Hey Snootch,
    1stbird
    Purchased 8/19/2005
    LS1
    6 Speed (M6)
    K&N Air Filter
    CAGS Eliminator
    DRL Disable
    Black on Black
    No T-Tops
    GM Factory Bra
    Glad to see someone else with a Firebird wants to install a PC!
    The frontend software i'm using is roadrunner, available here: http://guino.home.insightbb.com/roadrunner.html
    I suggest downloading it, and playing around with it, to get a feel for what it can do; which is a lot. RR is skinnable, and many members of this board make skins for it. GPS is one of the features I plan to add, but currently RR manages 19.3Gb of MP3's, a dozen movies, and XM radio for me. I suggest taking a look into the RR section on this board at Software & Software Development>Front Ends>Roadrunner. There are several other free frontends available as well. If I did not need the naitive XM radio support that is integrated into RR, I would probably use Centrafuse. Everything i've done to my car (PC wise) I've learned on these forums. Thanks for your compliments, and
    Good Luck!
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  5. #65
    Sep 2005
    Thanks, Snootch for the reply and the link to the download! I downloaded CarShell and played around with it, but Road Runner has the "look" that I am after. I just hope that my car will look half as awsome as your car does! I can't quite get my friends and family to understand why I'm so excited about CarPCing, but I'm sure once I show them, I'm sure to WOW them!
    Thanks again for the reply and link. And a special thanks to whom ever took the time to write this software. Was it Guino?
    Purchased 8/19/2005
    LS1
    6 Speed (M6)
    K&N Air Filter
    CAGS Eliminator
    DRL Disable
    Black on Black
    No T-Tops
    GM Factory Bra
  6. #66
    Aug 2005
    Plano/College Station, TX
    I'm very impressed Snootch! Always wanted a good ole' american muscle car like that.
    Would you mind going into a little bit more detail about that hood you created for your screen? I'd like to do one for my 7" Xenarc when I can afford it.
  7. #67
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    1st bird, why do you keep posting that picture of your car and that huge signature?
    it is a big waste of space and is annoying which is why we dont allow pictures in sigs o this forum.
  8. #68
    FLAC alti's Avatar
    NY
    BTW: for everyone else reading carshell is not a frontend in its current state.
    It is a shell like explorer.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  9. #69
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by Gearhead61
    Sure, The stock bezel around the radio is made of ABS plastic, so I just built upon it with strips of some 1/8" ABS sheet I bought from McMaster-Carr. I cut out the cross-piece between the radio and A/C using a jigsaw. Then I glued three ABS strips about 2" x 10" together in a sandwich using the ABS shavings/Acetone mix solvent adhesive. Once i got the "sandwich" made, I heated up one end using a heat gun to get it to curve at a 90 degree angle. Then I alignrd that corner I made with the top corner of the bezel. I then measured the distance across the top, and heated up the ABS to make the other top corner. Once I did this, I had this strip of ABS "sandwich" with 90 degree bends at either end, with a shape that resembles a staple when viewed from the side. I then glued it to the bezel using several applications of the ABS glue. Then I started shaping the edge of the hood using a orbital sander with 120 grit paper. Once I had it sanded to shape (which took a lot of work) I used the ABS glue as a filler, filling in small imperfections and seams. Then I sanded those spots smooth. I did this about 3 or 4 times until all the seams and big imperfections were filled in. Then I still had small pinholes which I filled using body filler "Icing". Then I sanded it again, and making sure it was smooth, sprayed it with Dupli-Color adhesion promoter, then 15 minutes later a couple of coats of Rust-Oleum black textured finish paint. I ground the mounting posts off of the backside, and used epoxy to attach four wide strips of velcro to the back.
    WORKLOG
    Webpage
  10. #70
    Oct 2005
    Hou. TX
    I don't remember if it has been mentioned here, but have you guys seen this monitor install by Curious?
    http://curioustech.home.insightbb.com/
    I'd like a big 9"+ monitor in my 99TA also, but I don't want to move the A/C controls. One thought I had was to mount a 10" monitor OVER the controls and have it hinged up top so that I could pull the bottom of the monitor out to angle it if I wanted to as well as pull it WAY out to reach under it to adjust the controls. It's just a thought, but I figured I would mention it.
    Does anyone here know of other TA or firebird installs like this? I really need to figure out the best solution for me.
    BTW, nice setup Snootch!
  1. pontiac sunfire 2000
    By Phantm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 10:00 PM
  2. 2000 Sunfire Install
    By CavityCr33p in forum Worklogs
    Last Post: 04-13-2005, 12:33 PM
  3. 97 Acura Cl carputer install
    By elserpiente in forum Show off your project
    Last Post: 04-11-2005, 05:48 PM
  4. Replies: 1
    Last Post: 02-03-2004, 02:02 AM
  5. Ready to install Carputer
    By petera in forum Power Supplies
    Last Post: 01-05-2004, 12:52 PM
